Mag rims catches on the steering tie-rod
- Vehicle: Hiluc
- Real Name: Derek
I am sure this is going to be a bigger pain than i suspect...but here goes....i have standard steel 15" rims on a 2003 hilux raider....i bought mag rims replacements....these rims are 15" x 8".....the issue is that the driver side steering tie rod end touches the mag rim....so the new rim sits too deep on the hub i suspect......which is weird..as the other side is ok.....if i am looking for a different mag wheel... is there a code i need to look for? ....any help or advise will be appreciated...tx Derek
- Town: Alejandria Antioquia Colombia SA
- Vehicle: Toyota Hilux 4x4
- Real Name: JAMES
Re: Mag rims catches on the steering tie-rod
I also have an '03 Hilux 4x4. After reading your post, I looked under my truck and the clearance between the tie rod and my 16" x 8" aftermarket rim is only about 3/4". i believe your problem is due to the 15" rims that your running. My truck has 16" rims, and I thought that was the size that came on all new '03 Hiluxes. After looking at my truck, I think if I tried to put 15" rims on it that there would be interference too. Best to trial fit the rims before buying.
- JAMES
- JAMES
- Bear
- Real Name: Ricky
Hello Derek
The alternative may be to get wheel adaptors if you still want to use those rims. The wheel adaptors must be hub centric though, for safety.
- Real Name: JAMES
The problem with wheel adapters is that they change the relationship between the tire/rim centerline and the spindle pivot point. This can make for some pretty sketchy handling.
