Snorkel DIY or Not
Posted: Wed Jun 10, 2020 5:21 pm
by Rinus
I'm going DIY have done it before on my Lost Hilux.
Sent from my ELE-L09 using Tapatalk
Re: Snorkel DIY or Not
Posted: Thu Jun 11, 2020 12:14 am
Not difficult to do, just get your positioning of the holes correct. If You've done it before then it should be easier 2nd time around.
Posted: Fri Jun 12, 2020 9:37 am
by pieta.swanepoel
Did mine myself. Make sure your templae is correct. Just remember: measure twice, cut once.
Posted: Fri Jun 12, 2020 2:18 pm
by Rinus vd Linden
I will post some pictures.
Posted: Fri Jun 12, 2020 2:21 pm
Looking forward to the pics!
Posted: Sat Jun 13, 2020 3:41 pm
by Rinus
Posted: Sun Jun 14, 2020 12:16 am
Lekker! Turned out well!
Posted: Sun Jun 14, 2020 6:56 am
by Rinus
I did not do the full airbox mod by removing the 60mm section and the vortex fin. Some owners do it, but it is a crucial part of the water seperation unit. How it works it creates a vortex that will force all particles to the outer side op the pipe (90mm). The inner section is 60mm, the air zone. At the end of the 90mm section is a water trap to expell the water. I left it all intact. The flow coefficient will be higher with the 60mm port but a few Kw's less, does not overrule the risk of water ingress.
