Afternoon Mud Dog & all here,
Reference is made to the above subject matter.
I need to know the following;
1. If I start with 3rd Gear Low Range on an uphill muddy surface or Bog Holes or River Crossings, is it a good gear to select? I've been using 2nd Gear Low Range on all the above-mentioned surfaces, but I'd once tried on 3rd Gear Low Range on an uphill muddy surface, and she performed very well and the momentum built was excellent. I just want to be sure if I could regularly use 3rd Gear Low Range on these kinds of surfaces in order to build momentum by keeping the engine rev low wherever applicable.
I normally keep my revs between 1,500 to 2,000 rpm on 2nd Gear Low Range, as between those RPMs and gear selection, the wheel slippage is very minimum, and that's what you want on muddy roads, to have minimum wheel slippage so that you don't bog the vehicle down, but was thinking if I could normally lift of on 3rd Gear Low Range, to could get more momentum, low engine revs and minimum wheel slippage if I kept my revs between 1,500 to 2,000 RPMs.
Regards
Shermohamed
N.B: Mud Dog: I am back to my Old Account now as you suggested, and have changed my password, I'd like my username to be Stallion on this old account if it's possible.
4 Low Range Gear Selection
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
Re: 4 Low Range Gear Selection
The gear change will work as long as you are not riding your clutch to pull off in 3rd gear (Depends on the incline and how thick the mud is).
Using the handbrake a little to get started can also prevent unnecessary wheel spin ...
HABOOB means "Dust Storm"
- Town: Dar Es Salaam
- Real Name: Shermohamed
Good evening Haboob,
Thanks for your response to my query, and yes, I always avoid riding the clutch, as that would wear down the clutch plate, unless if I installed a copper clutch
Thanks once again for your response on this.
Regards
Shermohamed
Regards
Shermohamed
