My hooter on the steering is fine, hooters when powered directly is fine.
I guess the relay is faulty, where does it sit?
Will 30 Amp replacement work?
2014 Hilux d/c Hooter Problem
- Town: Rustenburg
- Vehicle: Hilux D/C
- Real Name: Charl
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
Re: 2014 Hilux d/c Hooter Problem
Are you sure it is no the spiral cable?
Sent from my ELE-L29 using Tapatalk
- Town: Rustenburg
- Real Name: Charl
If I bridge the power to the hooter 12v Plus from battery it is working.
All steering controls functional and slip-ring looks clean and fine, fuse also good. relay suspect, but which one, dc hilux 2014
