Toyota Fortuner LCA replacement
Posted: Tue Jan 15, 2019 12:45 pm
Morning gents
So im at a crossroads with the Control arms on my 06 Fortuner 4x4. The upper and lower control arms both need bushes replaced.
I have 2 options:
1. Keep the OEM LCAs and UCAs and replace the bushes. I was considering going poly but this will also work out expensive. Also i was told that when removing the old bush, the bush would need to be burnt out, thereby weakening the metal.
2. Fit aftermarket (Teknosa) upper and lower arms (which comes with complete with bushes and balljoints etc.) The complete LCA from Teknosa is R980 per side and the UCA is R440 per side.
I would lean towards replacing the bushes on the OEM arms but the OEM bushes at Toyota are out of my budget at around R680 per bush.
What are your thoughts on replacing the arms with the Teknosa items? Has anyone had any experience with these?
Help will be appreciated.
I have 2 options:
