Happy new Prado owner - looking for top hinge for tail door!
Posted: Fri Mar 02, 2018 12:51 pm
by DanabaaiDaan
Hi guys - on my 2002 Prado VX 3.4 V6 A/T 95 series I am looking for a top hinge for the tail door (5th door) as mine is very worn out and it causes the door the rattle and bump when driving dirt roads or over speed bumps, and it is rather noisy.
I have so far gotten 3 options :
1) Buy a new one only available from Toyota - not an option, too expensive at more than R1300 !!!
2) Add washers to the bottom hinge to lift the door slightly - I don't think this will really help, as there is too much play on the top hinge - it would align the door better but still shake and rattle as the hinge is worn out around the hinge pin.
3) Have the hinge welded up and drilled out again with a new hole which would then tightly fit around the hinge pin - has anybody done this before and does is work / last long enough?
The last option is to try and source a good second hand one - virtually impossible ??
Hoping for some clever affordable advice soon !
Thanx - DanabaaiDaan
Re: Happy new Prado owner - looking for top hinge for tail door!
Posted: Sat Mar 03, 2018 4:06 am
HI Daan. Never done it before but it looks like a repair might be the way to go.
Replacing the pin with mild steel won't last, it needs to be a lot harder than that and welding the old one will soften it. Perhaps instead of a pin you could use a hardened steel bolt with a long enough smooth / un-threaded shank. You might also have to drill out the original holes to a slightly bigger size because they may have worn oval and match the holes to the bolt or vice versa.
Worth a try, given the dealer price for a new one.
Posted: Sat Mar 03, 2018 9:12 am
by JohanM
Hi Daan,
The ideal would be to replace both hinges and have the door readjusted and aligned at a panel shop.
All vehicles that carry the spare on the rear door has some ageing wear issues with the hinges and rattles. That's why most manufacturers that sell in Europe and USA and Canada have moved to sparewheel's no longer on the rear door and also got to do with lights visibility at an angle of 45 degrees ect.
I made a shim (0.6mm) for mine to fit the rear hinge which has partly solves the issue. The knocking/rattle noise from the rear door over ruts and gravel roads and humps have been better but still is there. It takes a fair bit more effort to hear it now from the back.
I did mine to get the lock to be more tight fit and it seems to work with easier opening and closing with less rattling.
It is not a permanent solution and I will look into replacing both hinges at some stage to rectify the issue with a new rear door seal to finish it of neatly. But it is costly approx 6K for all the work done with painting and adjusting including parts.
Posted: Sat Mar 03, 2018 3:00 pm
by DanabaaiDaan
Posted: Sun Mar 04, 2018 9:40 am
by pietpetoors
Hoor by N1 4x4 in Pretoria of daai 90 nog by hulle staan en of sy agterdeur dalk nog daar is. Probleem met 2de handse een is jy weet nie hoeveel hy al geslyteer is nie.
Vir my klink beste opsie soos jy wil laat maak, strip hom, boor gat grootter en sit nuwe pen in.
Wenk: Vir harde pen kry vir jou high tensile boutjie met baie lang skag, dan gebruik jy dit vir 'n pen, saag net die punt af.
Posted: Tue Mar 06, 2018 9:39 am
by DanabaaiDaan
Dankie Piet! Het met Corne by N1 gepraat en hulle het een wat glo nie te sleg lyk nie vir R550 + BTW. Ek moet dalk tog net eers die herstelopsie probeer....
