How to fix your leaking ARB air locker
Sifu-Lux
Town: Mount Vernon Illinois
Real Name: Andrew
Post by Sifu-Lux »
I was out playing around a few weeks ago and went to engage my diff locks for a rather challenging climb. (I have ARB RD01 air lockers fitted front and rear)
Rear engaged no problem, but as I flicked the switch for the front locker, whooosh, all the air pressure dropped in the system and the compressor kicked in, but could not
maintain pressure. I then checked and found the air blowing out my extended diff breather.... :oops:
So on getting home I had to face the fact that I had to remove the front diff, and for those who have done it, it's a big job on an SFA.
Anyway, youtube provided a quicker way to pull the steering knuckles off without complete dissasembly and remove the sideshafts / birfields.
If you need info on stripping the front axle, look here at my axle rebuild post:
viewtopic.php?f=92&t=9011
and also here:
How to Remove a Birfield Joint (The fast way) aka The Camo Method Toyota 4x4 Solid Axle by WheeliePete
https://www.youtube.com/watch?v=o3Y5bQGiezY
So here it started...
Sifu-Lux....I will miss you
Sifu-Lux
Real Name: Andrew
Re: How to fix your leaking ARB air locker
Post by Sifu-Lux »
After pulling the front diff out, I found the problem.
The rotary air seal end cap unit had popped the o-ring out, causing all the air to escape when pressurised at 6 bar...
On looking at the installation manual, I found the retaining clip missing. Further searching revealed it had come off and ended up in the axle housing.
Thankfully it did not go through the diff gears :shock2:
This is the missing clip, and this is where it fits in to the locker assembly
(15.86 KiB) Not downloaded yet
I still cannot determine why it unclipped ...
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
Here the air end rotary unit removed (not my picture, I forgot to take one) showing the o-ring grooves. My o-rings were now suspect, so I had to get new ones.
Locker seal housing.jpg (9.41 KiB) Viewed 3534 times
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
In replacing the o-rings, I scoured the interweb for the spec, not wanting to pay ARB part number prices :shock:
I have the ARB RD01 air lockers installed, my install manual lists an incorrect part number as I discovered.
The correct part number from ARB for the o-rings is 160205. Luckily I managed to find the equivalent part table chart
for the o-rings from ARB.
ARB part number: 160205
Standard part number: BS132V75 ---> 44.12mm ID 2.62mm CS Viton
Got them from Bearing Man (BMG) for R 10ea :thumbup:
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
Cleaned everything up (and a bit of rust due to lack of use...) and lubricated the new o-rings in clean diff ol and refitted everything.
I made sure the retaining clip was well seated and cannot move
Did a pressure test for 1 hour, no leaks!!!!
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
With all that done, I re-fitted the diff and re-assembled the axle (about 5 hours work)
(I also replace the pinion oil seal while I was doing this job and fitted a new locking nut which I did not cover in this post)
I also re-fitted the Aisin front locking hubs which i serviced and repainted. Look a bit better :mrgreen:
Took the Lux for a good drive and every is working as it should!!
Sorry t hear of your woes Andrew, but thanks for yet another informative post. Glad you got it sorted! :thumbup:
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
Mud Dog wrote: Tue Jul 04, 2017 6:06 pm Sorry t hear of your woes Andrew, but thanks for yet another informative post. Glad you got it sorted! :thumbup:
Joh, been a while Andy. Finally getting some time again to play with my Hilux. Thought I'd contribute some of my learnings again lol.
:thumbup: :thumbup:
Post by Mars »
Good post thanks.
