Good day Guys and Gals,
My 2.7 1999 Hilux has 585 000 on the odd, and has started using water. I don't see any leaks, and I haven't experienced any loss of power or anything untoward.
Last week I noticed a drip under the engine and traced it to the water pump. Apparently there is a little hole on the water pump, that tends to leak.
What i find interesting, is that it doesn't seem to drip constantly, some days it will, and others not. Is it maybe related to how far i drive before it tends to leak?
Best option to replace the water pump, or is there a sealant available?
Thanks in advance.
Intermittent leak on Water Pump - 3RZ 4x4
- Cheetah Drakie
- Vehicle: Toyota Hilux 2.7i
- Real Name: Peter
Re: Intermittent leak on Water Pump - 3RZ 4x4
My opinion is to replace the pump. Chances are that it's on it's way after that many kilos and it might just let you down on a trip or at a time when it's most inconvenient. I don't like using coolant sealing additives unless it's in a real emergency - they can restrict flow through the radiator and even the water galleries at the head gasket if those holes have constricted with corrosion / gunk over time.
- Club VHF Licence: X93-
Agree wit Andy.Replace the waterpump
Coolant leaking from that little whole usually means the pump seal is on its way out. Agree, replace the pump.
- Cheetah Drakie
- Real Name: Peter
Thanks guys, will do so ASAP
- Real Name: Marnus
Yes. The seal on the waterpump is definitely going.
