Hello All
does anyone know where i can get a wiper motor for a vigo besides from the agents as they want R2700.00
It s a Bosch motor made locally! help as no one seems to have and I am leaving on Saturday morning.
PS JHB area
VIGO WIPER MOTOR REQUIRED
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- Club VHF Licence: X93-
Re: VIGO WIPER MOTOR REQUIRED
Hi Quentin
Buy for you a bottle of C-Thru .Applied as per instruction on bottle and drive your bakkie until you get a wiper motor.With C-Tru the water just runs of from your windscreen and you do not need wipers.
- Town: ROODEPOORT
Okay so with Little (thanks Lollie) replies, I decided to try my hand again (3rd time, 1st semi successful lasted a month and a half, 2nd try no go) at recondition the wiper motor.
About half a bottle Q20, 2 tooth brushes and about 250ml of petrol I think I managed to get all the old and semi new grease out of the worm gear. the other half of the Q20 was used as a water repellent on the electrical circuit board.
Thanks to however suggested copper slip as a replacement grease on some earlier post, THANK YOU
Put a little bit of copper slip on the rear bearing and flooded the worm gear and electrical control plate with as much copper slip as I could.
re-assembled motor and tested, IT WORKED, R2223.00 saved (gemini parts R2223.00, stealers R2750.00).
now a little bit of advice to anyone trying to recon there wiper motor, make sure you now the position of the control arms as they can go back in about 4 different ways and also make sure that the rotational position of the control arms are correct, otherwise it is check remove then check again this can go on for about an hour as you cannot adjust the rotational position while the motor and linkages are installed.
and did I mention use as much copper slip as possible!!
Hopefully I will for at t be adding to this post at least a year couple of years.
God made man before
God made man before
- Oosie101
- Town: Roodepoort
- Vehicle: 2007 Toyota Hilux 4.0 V6 AT
- Real Name: Nicolaas
- Club VHF Licence: X298
Now I know where to go when mine starts giving trouble... Just around the corner with some beer.
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
As ek my goed saam met bier try regmaak weet ek, ek gaan ander moet gaan koopOosie101 wrote:Now I know where to go when mine starts giving trouble... Just around the corner with some beer.
- Town: ROODEPOORT
At least six and a bottle of captain for after I will bring the coke.Oosie101 wrote:Now I know where to go when mine starts giving trouble... Just around the corner with some beer.
God made man before
God made man before
