Hi Everyone;
I need some help with my luxie. Its a 2011 3.0 D-4D DC that I bought secondhand with 65 000km on the ODO. Its been for one service at 70 000km since I've had it. Not long after the first service the fuel filter light came on. At first it flashed, then I drained the water but instead of water I got clean diesel ??? After that it was a steady on light.
It went to the dealer and they replaced the fuel filter and all is well. Im at 76 000km and gosh darnit the light is on again. Is this normal?
Fuel filter light D-4D
- Town: Meyerton
- Vehicle: 2011 Hilux 3.0 D-4D 4x4 Auto Double Cab
- Real Name: Gerhard
- Omo
- Vehicle: Ford Ranger super cab 3.0 xlt 4x4
- Club VHF Licence: HC236
Re: Fuel filter light D-4D
You should check the diesel tank. Could be some old dirty fuel in there. Remember that the fuel filter is a cartridge one and is very sensitive. As soon as it gets a bit of dirt in the the sensor will come on. Rather change a filter than a injector or commen rail.
There a two kind of people. Those who pushes a door when it says pull and they who pull a door when it says push.
- dervdave
- Town: Sunderland
- Vehicle: Hilux 3.0d
- Real Name: Dave
Open the drain and let out any water etc then reset the light and see if the light stays off.
- Buffel 1
- Town: Kempton park
- Vehicle: Hilux 3.0D4D Legend auto
Have the same issue 3rd time now once on a 2.5 now second time on 30d4d
If it flash it is water if it stays on it needs replacement ....read the manual for better description of the exact prognoses or difference
Trick is insist they replace it if vehicle has guarantee left strighdom Toyota did it for me else wait till next service cheaper then. Around R300 if you have it done on another time it will be close to R1000 they charge minimum 1 hr labour else it's half hour labour with service
Good luck with the stealers
- dervdave
- Town: Sunderland
- Real Name: Dave
5 min job to change the filter yourself
https://www.youtube.com/watch?v=e9SLVYH2Dm0" onclick="window.open(this.href);return false;
- subok
- Town: Jhb - Somerset West
- Vehicle: Hilux 3.0 D4D 4x4 D/C - Kitted for overlanding
- Real Name: Kobus
- Club VHF Licence: HC152
I replaced my 2006 Vigo's fuel filter today and took this picture of the gunk in the bottom of the filter housing. I then removed the whole housing and washed it properly. This is the second time I've had to replace the filter.
[img]http://img.tapatalk.com/d/14/03/16/je7y2udy.jpg[/img]
- Town: Meyerton
Guess i'll have to change it then, thanks everyone. Its just annoying that in the 6 years I owned my 2.2 X-Trail not once did I have this problem. And its not like Im filling up with crap, Im at the SASOL putting in 50 ppm diesel.
- dervdave
- Town: Sunderland
- Real Name: Dave
Have you tried just resetting the light ?boanergesza1 wrote:Guess i'll have to change it then, thanks everyone. Its just annoying that in the 6 years I owned my 2.2 X-Trail not once did I have this problem. And its not like Im filling up with crap, Im at the SASOL putting in 50 ppm diesel.
