Can anyone give me advice on how best to drain the coolant from my radiator, resivoir bottle and cooling system on a 2005 KZ-TE ?
I want to drain all the water and fill with that pink coolant used by the agents.
How to drain all the water from 2005 KZ-TE
- Vehicle: Hilux 3.0 D4D DC 4X4
- Real Name: Marnus
Re: How to drain all the water from 2005 KZ-TE
On the radiator there should be a drain cock/plug and there should also be one on the engine block. On the D4D the engine block of which is based on the KZTE it is on the right hand side of the engine standing behind the vehicle.
