What i've done and where i'm going with my SFA
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
What i've done:
Snorkel
warn winch
rear diff lock
Long range tank
Gomad Canopy
Whats still to come:
In the long run would like to fit 1uz-fe lexus
35 tyres
what i'm busy with:
i went swiming on the weekend with my lux and water came in through the door and all my carpets got wet
so i've taken all the carpets out and hung hem up to dry, thinking about ruberising inside because this is bound to happen again i also drilled holes in channel just below the door there was about a litre of water stuck in there i would also like to do a suspension lift and body lift, was thinking
100 mm rectangular channel on top of diff and have longer u-bolts, brake pipes and shock mounts.
50mm extended grease able shackles.
50mm body lift, which will also help when i fit the lexus
i also want to change the diff ratios so that i will be able to run 35's with the lexus.
but carry on with the 2.8D and the 31's for now. won't matter if i have a lot of power and not much speed for now. what would be the right diff ratio's? also would like to keep local diff in the rear.
an issue with the suspenton lift what plan can one make with this steering arm arm? as it will be too low now? all comments and advice is welcome
Snorkel
warn winch
rear diff lock
Long range tank
Gomad Canopy
35 tyres
what i'm busy with:
Re: What i've done and where i'm going with m SFA
You would probably need all these:
Dropped Drag Link
Adjustable torque Rod
Steering Extention
Dropped Drag Link
Steering Extention
- Tarquin
Re: What i've done and where i'm going with my SFA
where does the last one come?
wont that arm thats one the diff be in the way of the shock if i put it next to the spring?
The last one is a steering extension. When lifting the body you have to extend the steering at some stage
- Tarquin
oh from the steering wheel to the box
- Tarquin
is snake racing the best place to buy those parts and a body lift? or does someone make them locally?
- Wurmscooby
- Town: Cape town
- Vehicle: 1996 2.4 SFA
- Real Name: Deon
send us a picture of the swimming.lol
- Town: krugersdorp
- Vehicle: 1988 SFA 4x4
- Real Name: richard
hi
it depends on how high you want to lift the body if the steering extension is going to be needed
- Tarquin
hirichardo1 wrote: hi
i would like to raise it 50mm.
who's the best to get a kits from?
- Tarquin
didn't have a camera with and we were rushing to tow it out, due to all the water coming in.Wurmscooby wrote:send us a picture of the swimming.lol
luck there was a tractor handy
you should be able to source it locally. I just love to browse SnakeRacings sight and it's the quickest place I could get pics of the itemsTarquin wrote:is snake racing the best place to buy those parts and a body lift? or does someone make them locally?
- Tarquin
i browsed there a bit as well
thanks for the pics, does any one know who does these parts locally
50mm body lift kit
dropped drag link
and adjustable torque rod
if anyone has done a 100 mm suspension lift, it would be great to see what you did at the drag link, it looks like myne will touch the spring if i put blocks in to lift it
50mm body lift kit
dropped drag link
- Town: Ellisras
- Vehicle: Toyota 2.2 93
- Real Name: Gary
If you want 100mm lift use procomp 4 in
- Tarquin
who sells that?offroad nut wrote:If you want 100mm lift use procomp 4 in
- Town: Ellisras
- Real Name: Gary
Pro Comp in Randburg
- Tarquin
have been searching the forum but have come up with anything, what diff ratios are standard in a 2.8D local diff rear.
what should the be changed too to be able to use 35's with a 1uz-fe engine
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Hi Tarquin, have a look here for the Z drag link I made. Just bent a new one to suit. viewtopic.php?f=92&t=9011&start=60" onclick="window.open(this.href);return false;
Here is a link to the adjustable torque rod I made as well viewtopic.php?f=92&t=9011" onclick="window.open(this.href);return false;
Sifu-Lux....I will miss you
- Tarquin
ok i've changed my mind, alan (hoppy), had a good point that 35's are over kill for a normal trail driver,
so i've opted for 33's with no suspension lift but still a 50mm body lift and an axel shift.
need to get front springs retensioned and change the diff ratio's for 33's with 1uz motor
any advise
any advise
- Tarquin
so i finally got some time to work on the lux
got the axle out gave it a good pressure clean and put it on the operating table removed and cleaned the first free wheel hub and it still looks in good condition,
but it seems the pin that holds the hub in lock and free is missing :evil:
previous mechanic must have lost it.
will be interesting to see if i can get it on its own or if i must buy the hold hub. when the hub sits perfectly strait and i move it slightly left to right it bumps in the middle,
but when i loosen the steering arm the hub freed up and moved smoothly, it seems to me that the bearing were too tight. can one buy an very thin space like the metal plate that's there? as far as i got today, will strip and clean the rest tomorrow
- Tarquin
Front Leaf Springs
Option 1: the guy in george charges R 600 to re-tention both front packs,
but he give's no guarantee.
Option 2: he says one can get OME copies from johburg which he says are excellent and sells them for R 1600 per pack.
Option 3: genuine OME, dono what they cost tho.
who sells the copy OME's in johburg?
what do you guys think?
so far i have 3 options,Option 1: the guy in george charges R 600 to re-tention both front packs,
- Baasvark
- Town: Virginia
- Real Name: Shane
I wouldn't retension, not money well spent! :evil: Did that on my SC and they sagged again not long after!
I dunno about OME copies - if they were that good the guys on this forum would have raved about them a long time ago.
The real deal will set you back around R18 - R20k.
- Tarquin
just for the front springs?Baasvark wrote:I wouldn't retension, not money well spent! :evil: Did that on my SC and they sagged again not long after!
- Club VHF Licence: X93-
I replace my suspension with Mikem suspension and very happy with it.
- Tarquin
who does mikem?
what would one be looking at for front springs?
- Town: krugersdorp
hi tarquin
the thin plates on the knucles you are talking about are called shims, they determine the bearing preload on the swivel bearings on the knuckles
mikem susension you can google and get their contact number I guess you can try ironman as well but the guys on the forum are more than happy with mikem
the suspension front and back could easily set you back R15 000
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
I would do both front and back......Tarquin wrote:who does mikem?
You will find Mikem here on the forum.... memberlist.php?mode=viewprofile&u=229" onclick="window.open(this.href);return false;
Speak to Cassie he had front and back done and it looks awsum....
[rimg=206x128]
[rimg=206x128]
- Tarquin
thanks johno
i sent Darrell a pm
i sent Darrell a pm
- Sifu-Lux
- Real Name: Andrew
Ah lekker job that :) Do yourself a favour an reinforce your spring perches and make sure they are 100% flat before you fit new front springs. These tend to bend over the years, then when you fit new springs they bend along the contour of the spring perch and distort.
Good luck
Good luck
- Tarquin
thanks enjoying it so farSifu-Lux wrote:Ah lekker job that :) Do yourself a favour an reinforce your spring perches and make sure they are 100% flat before you fit new front springs. These tend to bend over the years, then when you fit new springs they bend along the contour of the spring perch and distort.
Good luck
will see how it goes with re-mantling
haha thanks for the advise i saw what you did with your spring perches, looked like a good plan
- Tarquin
i've finished stripping the front diff, clean, reinforced the perches and given it a light sand so i can re-spray it.
when i dive in 4x4 on the tar road it feels like the handbrake is on, so now i sat down and checked my diff ratio's: my front diff i marked the pinion at one place and the crown wheel with some tip ex. the pinion almost turns 5 times to 1 crown revolution which means it a 4.88:1.
I have a M80 local diff rear and i never thaught to look but there's a plate and its a 4.55:1
is a m80 the standard SFA rear diff? maybe the prvious owned had a problem with it and the mechanic didn't check the ratio's and just put in another diff
this means the rear diff is coming out to correct this.
on the terms of leaf spings i'm going to spend a little more and go with OME, going to change front and rear packs, but keep my TJM shock as they are still good.
spoke to megaworld PE and they don't have the rear packs, they'll only be getting next week Wednesday or thursday. then i'll do some shopping in PE
i've also fitted Alan's beautiful upgrade disks when i dive in 4x4 on the tar road it feels like the handbrake is on, so now i sat down and checked my diff ratio's: my front diff i marked the pinion at one place and the crown wheel with some tip ex. the pinion almost turns 5 times to 1 crown revolution which means it a 4.88:1.
- GeorgeJvR
- Town: Louis Trichardt
Aint the front diff ratio also 4.55? some diesels were 4.55 where the petrol were 4.875.....
Kom wat wil ek bly 'n Bul!
- Tarquin
is it written somewhere on the front diff?GeorgeJvR wrote:Aint the front diff ratio also 4.55? some diesels were 4.55 where the petrol were 4.875.....
i worked it out and the pinion almost turned 5 times to 1 crown wheel rotation
how many teeth does the crown wheels have for a 4.55 and a 4.875?
- Sifu-Lux
- Real Name: Andrew
See here for diff info. viewtopic.php?f=67&t=5017" onclick="window.open(this.href);return false;
- Tarquin
thanks Andrew
very interesting read
- Tarquin
got all the ceals and gaskets from toyota today, will make some time to work on it!
what do you guys say is it better to paint or leave it as metal? worried it'll rust now that there is no greasy oil dripping out
- Sifu-Lux
- Real Name: Andrew
Give it a light polish with 600 grit water paper then a light wipe with some oil until you assemble it. Don't paint it, the felt outer seal should run on the bare metal. Don't worry, it won't rust
- Tarquin
so i've done it and baught OME front springs: R 1885 ea
compared to my old ones: can't say there's a massive differnce, will see if they sag or not
only thing i saw now when i got home and checked properly the spring with the + on it (driver side as i understand it) is quiet a bit more bent than the other one is this normal?
they wouldn't sell me the springs with out the ani-inversion kit, even though i told them i had already re-inforced the saddles. so i have a OME kit for sale R 100 ex shipping Also baught 2 rear audi calipers for a disk conversion from team merbeda in PE. R350 ea
The driver's side is flatter than the passenger side ..... reason is that the driver's side pedestal on the axle sits higher because it's so close to the diff housing.
- Tarquin
ahh thanks andy, was getting worried! everything is on track then
- Sifu-Lux
- Real Name: Andrew
I take it they did supply you the spring pack for the diesel Hilux? Petrol and Diesel packs are different. Diesel has more leaves to account for the extra weight of the engine over the petrol model.
- Tarquin
yea they gave me the diesel one's, it has 6 blades
- Tarquin
manne ek is klar met die diff
got 3/4 of a day today to work on the lux and i put the front diff together. didn't do a full thread on re-doing a front diff cause Andrew already did an excellent one and i don't want to duplicate his work.
will try tackle the body lift tomorrow, but lets see how the day goes if i'll have time :roll:
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Looking great,while out change the bolts to stainless steel on the hubs
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Tarquin
good idea i'll do that
- Blitzkrieg
- Town: Glen Marais
- Vehicle: 94 Hilux D/C V8 Lexus. 2009 LC Prado 4.0 V6
That's a very nice job you've done there!
Please let me know when you have time so I can send mine for a overhaul to.
- Sifu-Lux
- Real Name: Andrew
Nice job, looking good! I'm keen to see your step by step detailed tutorial on the body lift with lots of pics . I never got around to doing that on mine.
- Tarquin
thanks guys. you can bring it any time just a bit far away
already started the body lift and haven't taken any pic's will back tract and do a proper thread
- Tarquin
Got my rear side shafts and disks back from the engineers
also turned my torque rod into an adjustable one and shortened it by 40mm
since i'm putting ome spring in the front with new shackle rubbers i thaught id make my shackles greasable
fitted my front diff 35mm further forward
my front shock's are a bit short now
- Tarquin
apologies for the grainy pics
- Thunder02
- Town: East Rand
- Real Name: Neil
Looking good,what's the plan with the shocks?
Fitting spacers,or longer shocks,apparently the cruisers are longer by 40mm.
www.4x4direct.co.za
www.4x4direct.co.za
- Tarquin
going to try it out like it is, was hoping not to buy new shocks, as the old ones are still fine.Thunder02 wrote:Looking good,what's the plan with the shocks?
will look at the cruiser's ones if it comes to that
- Tarquin
a pic of your gear cover i'm very happy with it and am looking forward to seeing it in action
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
Looking good so far. Planning on starting mine in January, complete overhaul and heart transplant.
- Tarquin
whats going into your lux?Froll wrote:Looking good so far. Planning on starting mine in January, complete overhaul and heart transplant.
- Thunder02
- Town: East Rand
- Real Name: Neil
Glad the hole for the gear lock is correct,not always easy to work of a pic
www.4x4direct.co.za
www.4x4direct.co.za
- Froll
- Town: Vioolsdrift
- Real Name: Roger
Have not realy decided yet. Will start a thread when I start.Tarquin wrote:whats going into your lux?Froll wrote:Looking good so far. Planning on starting mine in January, complete overhaul and heart transplant.
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
Looking vry nice so far
HABOOB means "Dust Storm"
Targuin
The anti rattle springs on the standard brake pads also work om the upgrade brake kit.So if you still have got yours put it back.
- Tarquin
i haven't got them anymore, they must have gotten lost with previous owner :evil:
