Special tool for inner diff seal Hilux SFA .
- Novi Norval
- Town: Bryanston Johannesburg
- Vehicle: 91 Hilux 4Y 4x4 d/c V-6
- Real Name: Eugene
Thought id share this , its a special tool i made up for replacing the inner oil seal on the front solid diff on SFA Hilux , two taps with a light hammer and its in place without any possible damage .
- 536236_10151449974719698_1979920835_n.jpg (44.2 KiB) Viewed 1026 times
[If u reach a fork in the road just carry on straight ]
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Re: Special tool for inner diff seal Hilux SFA .
Dit is baie nice sal ook 1 moet kry (het n socket ext gevat )
- Novi Norval
- Real Name: Eugene
Werk soos n bom , moeite werd om een op te maak .
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
These work well. Here's a link to the one I made, with a drawing. Just page down till you find it
viewtopic.php?f=92&t=9011&start=30" onclick="window.open(this.href);return false;
Sifu-Lux....I will miss you
- Novi Norval
- Real Name: Eugene
Nice truck !
