prior to Engine Warning Light coming on, here is what i observed when i was driving back from Lesotho this passed weekend.
i started noticing that my speedometer vs GPS speed was way off the mark, while driving 120km/h on the speedo, GPS would read 135km/h which is way off the normal mark because GPS 120 would be around 123 on the speedo.
Monday morning as i was pulling the truck off the yard i noticed Engine Warning Light was on, switched off the truck & back back on the warning light was still on. initial thought was its due for service. but on second thought, my van is only on 187700 & its due for service on 190000.
as i read on other forums, they talk of error codes detected buy computer, which might be the results of coolant levels, temperature or something to do with exhaust (i removed the cats, could this be the result perhaps, MINI cats were fitted also)......now im confused
![DontKnow :dontknow:](./images/smilies/dontknow.gif)
![SOS :sos:](./images/smilies/help.gif)
could you please give some direction if its still safe to drive it or what might the problem be
