I am buying a DC-DC charger tomorrow, its a 20a for R1208.00
now that to me is a good price if you conciser that a NL solenoid goes for about R800
MotorMate DC-DC charger
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Re: MotorMate DC-DC charger
Jy kan die 30a kry vir R1700 as ek reg onthou
Sent from my couch using a potato
- Johan Kriel
- Town: Okahandja
- Vehicle: 2.5 SC 4x4
- Real Name: Johan kriel
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
Johan die manne kan my reg help as ek verkeerd is of van dit uit los. 'n DC-DC is meer effektief as net you normale battery in parralel met you deep cycle te sit.
Glo kort 'n deep cycle ook 'n bitjie hoer Voltage as 'n normale battery om reg gelaai te word.![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
- Stubs
- Town: Onrusrivier Hermanus
- Real Name: Stuart
check our one our wayne
http://www.4x4direct.co.za/shop/electri ... -p-566.htm" onclick="window.open(this.href);return false;
cheers
Stubs
cheers
Stubs
- Johan Kriel
- Town: Okahandja
Ja as dit n intelegente charger isWayneSchalk wrote:Johan die manne kan my reg help as ek verkeerd is of van dit uit los. 'n DC-DC is meer effektief as net you normale battery in parralel met you deep cycle te sit.
![Shh :shh:](./images/smilies/icon_shh.gif)
Johan Kriel
Legend 50
Legend 50
The Dc-Dc charger charges your dual battery at it's nominal rate even though you front battery is charging at a lower rate. Eg. My front battery charges at 13.6v while the dual battery charges at a constant 14.2v (the voltage I set it at). So the deep cycle gets charged at it's prefered rate and thus charges to 100% it's capacity. When charging with NL you have to bump up your alternator voltage in order to get the 14.2v at the dual battery which in turn give yoh a charging voltage of about 14.5 to 14.8v at your starting battery. So if you keep the alternator as is, you are going to get about 13.2v to 13.5v which will only charge die deep cycle to 80 or 90% it's capacity.
- Johan Kriel
- Town: Okahandja
Correct, and if the batteries are not the same type, and size etc, a DC to DC will be better than with an alternator, even if it charge only at 13.8 Volt like the motormate?, all I want to high lighted! ![Big Grin :D:](./images/smilies/icon_e_biggrin.gif)
Johan Kriel
Legend 50
Legend 50
