Once engaged 4x4 low and the ABS light on the dash came on, as it should, no problem. But going back to H2 the light remianed on
So on Thursday, took off all 4 ABS speed sensors and cleaned them, both rear ones were fairly dirty and the front ones not so bad, however the light remains on. (While at it I adjusted the rear brake shoes and the handbrake works lekka again)
Questions:
1. Should I disconnect the main battery to reset the system?
2. What else generally goes wrong?
3. Is the maybe a switch/relay on the transfer case that could have packed up, and if so where exactly does it sit?
So last night I started going through the circuit diagram and noticed that there are 2 ABS ECU's behind the driver side kick panel, do these generally fail?
KZ-TE - ABS light stay on
- Donkey
- Club VHF Licence: X122
Tumelo Maketekete
- moosakham
- Town: welkom
- Vehicle: 3.0 d4d d/c
- Real Name: Moosa
Re: KZ-TE - ABS light stay on
howdy
i might be wrong but, after cleaning sensors, initiate 4x4 again and then disingage... should reset..
otherwise yip, disconnect battery for 10 minutes and reset.
hope it works....
hope it works....
- FJCruiser-ZN
- Town: Durban
- Real Name: Tony
- Club VHF Licence: X224
Donkey
I suggest looking at the circuit that disengages the ABS in LR 4x4.
There must be a switch somewhere on the tranfrer case that is probably just sticky.
I am sure Hoppy can shed some light as he knows hiluxes inside out.
Keep us posted
T
Keep us posted
T
2013 FJ Cruiser 4.0 V6 4x4 AT
2012 Jurgen's Xcape
2012 Jurgen's Xcape
- Donkey
Thanks guys for the replies/remedies, will try them out on Fri and advise.
Tumelo Maketekete
- Donkey
Disconnected battery on Fri to reset ABS, and it stayed off only for a few mins only to come back on again, so will investigate a bit more.
Tumelo Maketekete
- 4x4 Junkie
- Vehicle: Hilux 3.0 D-4D 4x4 DC A/T
- Real Name: Julian
Hey Tumelo,
I now have the same trouble on my cabby. Did you ever figure out what was wrong on yours?
If you still have blank pages in your passport, it's probably time for a road trip.
- Donkey
Hi Julian, last I took off the 4 sensors and cleaned them, but it still stays on. Honestly been lazy on my part to follow on. I'm suspecting there is a switch on the gearbox that could also be faulty.
Tumelo Maketekete
