Windscreen Wipers problem
Mikie
Town: Kyalami
Vehicle: Hilux 2006 3.0D4D 2x4 DC
Real Name: Mike
Post by Mikie »
I am coming to ask the Slim manne for help.
My windscreen wipers died this morning
Turned them on they went all the way up and on the way down pop went the fuse, I replaced the fuse and pop again, so I have a short somewhere.
How do I find the problem?? Going to the Waterberg on Thursday so I need to get this sorted by then. whats the easiest way to find the problem??
Re: Windscreen Wipers problem
Post by CasKru »
Is there any other devices powered by the same fuse?
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
CasKru wrote:Is there any other devices powered by the same fuse?
Doesn't seem so, the fuse only says "WIP"
I've mentioned it here before ... if the wiper motor labours hard enough it will pop the fuse even if there is no short. Often the wiper bushes become stiff from dirt / corrosion. Remove the wiper arms to expose the shafts and spray them with some penetrating lubricant (Q20 or other). Replace the fuse and try it without the arms connected ... should run if there is no fault with the motor or a short.
Post by CasKru »
Was going to suggest to also remove the wiper motor and maybe clean it out and grease it again as well
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Mud Dog wrote:I've mentioned it here before ... if the wiper motor labours hard enough it will pop the fuse even if there is no short. Often the wiper bushes become stiff from dirt / corrosion. Remove the wiper arms to expose the shafts and spray them with some penetrating lubricant (Q20 or other). Replace the fuse and try it without the arms connected ... should run if there is no fault with the motor or a short.
Geniune?? I would never have thought this. Makes sense though, as they worked perfectly until this mornign, they never seemed to labour though. I would find it strange that a short developed over night without anything being fiddled with, is there a better way to test without going through 5 million fuses? I hate popping them successively, costs money.
Caskru wrote:Was going to suggest to also remove the wiper motor and maybe clean it out and grease it again as well
Cassie, you got any idea hwo hard that motor is to get out?
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Andre's Post here sounds exactly the same as mine, viewtopic.php?f=3&t=27400" onclick="window.open(this.href);return false;
looks like this afternoon am removing wiper motor, cleaning and lubing, I hope this isnt difficult, I hate to sukkel
Try my suggestion first.
Not sure about the Vigo, but the motor may be on the engine side of the firewall. Then it's quite easy to remove, but thye motors themselves don't really give hassles ... induction motor, so no brushes and only the field coil that can burn out ... the little "gearboxes" with the worm and ring gear are fairly protected from the elements under the bonnet, so it's not often that they need to be serviced, but if my suggestion fails, that would be the second step to remove the motor and service.
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Mud Dog wrote:Try my suggestion first.
Thanks Andy. You may just be my hero
Here's holding thumbs! :lol: :lol: Let us know what happens. ;-)
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Will do
Oubaas
Town: Rustenburg
Vehicle: 2008 Toyota Hilux Raider 3.0 D-4D D/Cab
Real Name: Dewald
Post by Oubaas »
Indien jy nie regkom nie, koop 'n botteltjie C-thru by Midas, Game, etc. Smeer dit aan die ruit soos aanbeveel. Jy het nie wipers nodig nie, dit laat die water afhardloop van die ruit af. Hoe harder dit reën en hoe vinniger jy ry, hoe beter hardloop die water af. Ek gebruik dit al jare en dis 'n moet vir enige voertuig.
Every little boy wants a toy truck...
When the boy grows up it's only natural to want the TOY truck!
All I ask is the chance to prove that money can't make me happy.
Jaws
Town: Sharonlea
Vehicle: 2009 D4D 4x4
Real Name: Herman
Post by Jaws »
No suck luck on the Vigo I'm afraid , wiper motor well hidden behind some plastics. Lots of reports of the wiper motor failing on the Vigo.
:thumbup:
Jaws
Town: Sharonlea
Real Name: Herman
Post by Jaws »
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Reason: Fix image tags
:thumbup:
Jaws
Town: Sharonlea
Real Name: Herman
Post by Jaws »
R2500 for the motor from spare shops, R2900 from the stealers
:thumbup:
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Seems I am in luck, I removed the blades, then the covers, then removed the 2 bolts and slid the complete motor out.
As recommended I sprayed a decent oil into all moving parts, reconnected the motor to test and it worked, I then put it back in place and replaced all parts, seems to be working now, very strange, could be some old oil and corrosion did make it tight.
If it fails again I will remove it again, clean and lube, thanks for all your help.
Post by Family_Dog »
I posted this earlier today, but my post has gawn! :shock:
Andy, are you sure about the above statement? An induction motor works off AC, not DC, unless the DC is converted to AC, but that seems a strange way of doing things. The wiper motor supplies a fairly decent amount of torque and a DC motor with brushes is excellent for supplying this.
Eric, you're probably right ..... I must be getting confused with an appliance motor that I stripped some time back. :blushing:
Glad you came right there Mike! ;-)
Appliance motors very often are induction motors because they are silent. Think of a standard oscillating fan, no noise, it is an induction motor. Same for a swimming pool pump, air con, fridges, etc. But a vacuum cleaner ain't! It is a high-revving, irritating, noisy motor that uses brushes and a commutator.
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
This morning they are still working and they also seem to move easier, my suggestion, if you have the time and inclination, pull yours off and lube the parts before it gets stuck, well worth it, now I somme want it to rain :boss:
Jaws
Town: Sharonlea
Real Name: Herman
Post by Jaws »
Mikie wrote:This morning they are still working and they also seem to move easier, my suggestion, if you have the time and inclination, pull yours off and lube the parts before it gets stuck, well worth it, now I somme want it to rain :boss:
Good news !
:thumbup:
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
This lasted 6 months, popped again this morning, I need to pull it out again and reoil the moving parts again. I think its definitely on its way out
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
I fear it may just about have given up now, I have removed it and greased all movable parts, Fuse still popped this morning
Only havent opened up the motor yet, is that doable? Spray some oil in there?
Sifu-Lux
Town: Mount Vernon Illinois
Real Name: Andrew
Post by Sifu-Lux »
You can open up the motor, check the bearings are turning freely, and also the brushes are still okay as well as the commutator. That's really all there is to check in there.
You could also check the windings are still okay with a multimeter by checking the continuity between the appropriate commutator segments.
Sifu-Lux....I will miss you
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Sifu-Lux wrote:You can open up the motor, check the bearings are turning freely, and also the brushes are still okay as well as the commutator. That's really all there is to check in there.
Thats all getting a little high tech for my level. I can open clean and re oil thats about as much as I can do, they go up halfway and when its time to return, POP goes the fuse, heavy strain it seems, bearings may be dirty.
JamesC
Town: Potchefstroom
Vehicle: SRX 2.5 4x4 D/C
Real Name: James
Post by JamesC »
You need to open the motor completely. Then I used copperlube - runs like a charm. The ghries they put in there becmes sticky over time and causes the motor to work too hard and pop the fuse.
No need for a new motor - just open, clean and lube with good stuff
James Cameron
0834431879
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
JamesC wrote:You need to open the motor completely. Then I used copperlube - runs like a charm. The ghries they put in there becmes sticky over time and causes the motor to work too hard and pop the fuse.
Must it be copperlube? Q20? Bike Chain oil?
JamesC
Town: Potchefstroom
Real Name: James
Post by JamesC »
Q20 won't last. Best is copperlube or a high quality ghries
James Cameron
0834431879
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Post by Stef »
Motorbike chain oil could also work (the off road one), used it in my kart racing days...that stuff handles any conditions, but copper type grease will be better in long run.
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
I have good quality Bike chain oil, gonna try that
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Ok its working again, sprayed some dirt bike chain lube in there, its pretty much melted the grease, everything moves again, lets hope for longer this time, I am out of Yellow fuses :P
Obelix and Dogmatix
Town: ROODEPOORT
Vehicle: HILUX 4.0 V6 4x4 named Obelix, donated to some clown, HILUX 4.0 V6 4x4 named Obelix II Onca front and rear Amade extreme Suspension and under water breathing apparatus
Real Name: Quentin
Post by Obelix and Dogmatix »
Seems like it is my turn now!!! :thumbdown: :thumbdown:
Thanks to all who posted on this post, Will try tomorrow!!
God made man before
woman so as to give him time
to think of an answer
for her first question
Post by 4x4BEES »
Did you sort it out??
Just a quick question.
How often must one check these wiperblade motors?
How does one service the SFA one?
Mine is not giving trouble, just want to know.
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Oh yes definitely
Still running and working like a charm
Obelix and Dogmatix
Town: ROODEPOORT
Real Name: Quentin
Obelix and Dogmatix wrote:Seems like it is my turn now!!! :thumbdown: :thumbdown:
mine works like a charm again as well, so if the first 'service' was required after 7 years hopefully it will be another 7 before the need to strip it out again, (I used a lot of grease)
God made man before
