Cutting alluminium sheeting
yotaman
Town: Hartenbos Western Cape
Vehicle: '99 2.7i Hilux 4x4 S/C
Real Name: Shane
Post by yotaman »
Without having a fancy cutting machine or special plasma cutter what advice can anyone give me to successfully cut alloy sheeting. Is there perhaps a special disc for this? :beg:
Albert Einstein
WayneSchalk
Town: Krugersdorp
Vehicle: 2019 Toyota Hilux 2.8 GD-6 4X4 DC Auto
Real Name: Wayne
Club VHF Licence: X117
Post by WayneSchalk »
Jigsaw with the right blade. The challenge is cutting in a straight line
jacques kotze
Town: Nelspruit
Vehicle: 2,8 4x4 Auto Fortuner. 2,8 4x4 Hilux singlecab.
Real Name: Jacques
Re: Cutting alluminium sheeting
Post by jacques kotze »
I'm using a normal roll saw for cutting wood, I use a normal wood blade but Aluminium blades is available. I cut up to 3mm aluminum.
kfxnando
Town: Germiston
Vehicle: Ford V6 3.4 Courrier soon to be powered by Yamaha!! Jeep GC 4.7 V8, Aygo broken traded for a Kia Picanto.2ex, 2012 Jeep GC 5.7 V8 Ovrrland
Real Name: Fernando
Post by kfxnando »
from my understanding and limited experience, most blades that can cut wood, will cut aluminum sheeting!!
am busy with a little project that I could display here later, and the heat sink for the electronic components is cut with something very similar to an offcut machine with a steel blade!!!
DO NOT USE AN ANGLE GRINDER with A NORMAL CUTTING DISK ON ALUMINUM
to file aluminum one uses plumbers chalk, or normal chalk to stop a file from getting clogged up with filling!!
when porting aluminum cylinder heads, we used grease to stop the pear shape cutter from clogging up
so you could try either use chalk or grease to stop the blade from retaining the aluminum filing, however doubt that the big open teeth blades will clog up easily!!
hope this helps!!
:cooldude:
Keiler
Town: Durbanville
Vehicle: '05 4.0 DC manual-ARB - WARN - KC - DUAL BATT - OLD MAN EMU - BFG 31 10.5 15 and 4.0dc 4x4 and 320 dc isuzu 4x4 to recover the hiluxes
Real Name: Koos
Post by Keiler »
i use babygrinder with slimline blade, very thin blade and finnish off burrs with a file for the odd cuts on thin sheets,
get most of my stuff pre-cutt from NFM, save you time and you can decide on buying p/kg which sometimes work out cheaper than per sheet specialy with odd size offcuts
...leave a trail for others to follow ..... if they dare !!!
yotaman
Real Name: Shane
Post by yotaman »
Tks for the tips and advice to all you guys
Albert Einstein
Buffel 1
Town: Kempton park
Vehicle: Hilux 3.0D4D Legend auto
Post by Buffel 1 »
with the best effort in the world have I not been able to cut it straight
Leave it for a pro
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Post by Hi-Hilux »
Clamp net vir jou 'n straight edge langs jou lyne, dan sny mens reguit
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Post by Polarbear2008 »
Ek stem saam met die comment oor die jigsaw eerder as die angle grinder, want die "waste" is baie minder met n jigsaw en ook die afwerking daarna.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
A jigsaw with a straight-edge works well but there are special thin blades for cutting alu / copper with a grinder. A normal blade creates too much heat and clogs. Even better is if you have a variable speed grinder and cut on a slow speed with the thin blade .... cuts are fairly clean. ;-)
MOFASA
Real Name: Johno
Club VHF Licence: X119
Post by MOFASA »
Mud Dog wrote:A jigsaw with a straight-edge works well but there are special thin blades for cutting alu / copper with a grinder. A normal blade creates too much heat and clogs. Even better is if you have a variable speed grinder and cut on a slow speed with the thin blade .... cuts are fairly clean. ;-)
You can make any grinder variable speed, all you need is a light dimmer switch in a box on connected in the power cord between the plug and the grinder....
Then all you do is adjust the speed, but dont turn it down to much as it will burn out the armiture or the brushes due to overheating as the fan does not spin fast enough to cool the windings.......
ImageImageImage[rimg=206x128]
Traveler
Vehicle: Pathfinder 2.5 LE AT
Real Name: Heinrich
Club VHF Licence: X81
Post by Traveler »
I use a long spirit level that I clamp to the surface, and then it serves as the guide for the saw. Works very well. A long piece of angle iron can also do the job.
I have a couple of sheet of aluminium that is looking for someone to take over.
Know what you don't know.
Return to “Open Discussion”
