How to run in your engine
- Gunta
- Real Name: Mark
I have seen many topics on how to run in your engine and there are many school's of thought. The one I found very interesting was the one where the engine was driven hard as the the author explains over here.
http://www.mototuneusa.com/break_in_secrets.htm" onclick="window.open(this.href);return false;
I spoke to a pilot friend of mine and he says this is the same way they run in their engines. Basically what they are saying that if run in slowly the rings dont bed in properly and get glazed because they are not forced up against the cylinder walls. If you drive it hard for the first 20 miles the compression forces air behind the rings bedding the rings in properly and they say your engine should make more power and use less oil. Another mate of mine was also telling me that when Porsche drive the cars of the floor they take it for a hard test drive.
Any thought out there. I tried looking for previous post on running in an engine but could not find any.
- Petrusd
- Town: Stellenbosch
- Vehicle: 1997 2.4 Hilux DC 4x4 / Yamaha Motorfiets
- Real Name: Petrus
Re: How to run in your engine
"Drive it like you stole it"
I've heard of this 'school of thought' before, and have to agree that there is merit in the logic, but would be hesitant to do this with a motor of mine. I personally don't believe that the rings will 'glaze' so quickly with a slow run in
..... just keep it below 6½ thousand revs for the first 30 minutes!
![Big Grin :D:](./images/smilies/icon_e_biggrin.gif)
![Thinking :think:](./images/smilies/icon_think.gif)
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
- Maddoglips
- Town: P.E.
- Real Name: Zane
Mark my 2CW
Intial start, let engine warm up - cut out and check levels and for leaks - let engine cool down
If all ok, take vehicle for drive of 100k's in town and again return to check all items for leaks,levels loosening ect.... and let cool down.
Take vehicle out again, run in town till at running temp, then hit free way keeping her at low revs for awhile and gradually build by a thou, run her there in top gear for roughly 3/4ks and bring her down by half to 1k again and hold for 2km's
Repeat and at each time increase by a thou over the previous max till you at your happy/max rev spot on the engine and then park up have a few beers and let her cool down while checking over everything again.
Time to go home, start and run her gently till warm and then drive her at high/normal driving revs and walla she's run in.
Never had a prob so far but every 1 has there own method so I'm sure you gonna hear alot still.
Good luck Zane
Good luck Zane
Various programs on Discovery has already shown how a BRAND NEW vehicle gets put on a dyno and pushed HARD - some for a few seconds, some for a few minutes.
YET, most owner manuals tells you how to run in your new engine - on page 200 of the manual ... go figure
Mostly it warns against TWO things:
1) low speed in a high and labouring the engine.
2) extended periods at any given speed / engine rpm. a new engine NEEDS to move through the rev range continually.
PERSONALLY - I take it carefully for the first few hundred kilometer, and no "robot to robot" stuff for the first 1000 km. YET, when I do get to a down hill with no other traffic I gently accelerate and increase the speed as far as possible - thus the engine gets to "breath" without labouring.
When I rebuilt my tweaked 4Y I did alot of research... finally used the method here:
Unconventional, but worked very well!
- Gunta
- Real Name: Mark
well its 50/50 with the comments. I have to say I have re built a few cars now and all of them except the last one, a 16v golf which I re built and stroked to 2.1L, blue printed, knife edged crank a, lightened flywheel and solid lifters in. that golf I pretty much gave it horns from the time I warmed it up. I had it on the Dyno and it was pushing 110kw on the wheels. my fuel consumption on the open road was around 14km/l which was incredible considering its power. I have to say it never used a drop of oil and revved easily to 8500 as smooth as a bird. that is why I have had thought about running it in the same way.
I plan to dyno it pretty soon, so I will see if it works.
- Gunta
- Real Name: Mark
Mr B that is the same website that I put the link on. I am glad you have also tried it. How many km have you done now and have you had it on the dyno. From what I have heard you should get between 5 and 10% more power.
- kfxnando
- Town: Germiston
- Real Name: Fernando
regardless of how one runs the motor in!!
upon start up, keep the revs above 2000rpm, for two minutes!!
reason to bed in the cam bearing!!
beyond that with the running in it depends on the type of materials that one is dealing with, like the info say!!
also have that link saved!!!
drive
agree!!
enjoy!
drive
Petrusd wrote:"Drive it like you stole it"
agree!!
enjoy!
- Gunta
- Real Name: Mark
Well guys this is what I did. Started the motor and let her run for 20min and checked for leaks and noises. Fan was not coming on (forgot to connect the 2 wires on sender unit) fixed that and everything was looking great. Took it on the road and went through the gears to about 5500 rpm. Put it on the dyno and set up the fuel mixures and timing and gave it horns. Motor is pumping out 82kw on the wheels and the torque curve is flat with 90% coming in at 1500rpm. Took it on the road and gave it stick and it runs like a baby.
All wet and smelly?Took it on the road and gave it stick and it runs like a baby.
![Image](http://www.audiokarma.org/forums/images/smilies/pawprint.gif)
![Image](https://i.postimg.cc/9fGpmSTW/4-in-1-Signature.jpg)
- kfxnando
- Town: Germiston
Gunta wrote:Well guys this is what I did. Started the motor and let her run for 20min and checked for leaks and noises. Fan was not coming on (forgot to connect the 2 wires on sender unit) fixed that and everything was looking great. Took it on the road and went through the gears to about 5500 rpm. Put it on the dyno and set up the fuel mixures and timing and gave it horns. Motor is pumping out 82kw on the wheels and the torque curve is flat with 90% coming in at 1500rpm. Took it on the road and gave it stick and it runs like a baby.
82kw!! to some might sound little, however prefer a realistic number to inflated numbers!!
take note that a 3.4L V6 has only around 53kw/71rwhp
allow me to have some fun here pls!!
82kw on the wheels at JHB, by the way, where did you have it dyno??
4x4s have a loss of 39%
82kw on wheels = 134.43kw at flywheel
134.43kw on motor at altitude = 170kw at the motor at sea level
howz that sound, howz that sound compared to the original specs??
ok!!
have ans my own questions, google works great!!
![Laugh2 :laugh2:](./images/smilies/laugh2.gif)
from wikipedia
will presume in this case a full unrestrictive exhaust system that the original one did not have, and a better EFI then the original one!!The 7M-GE was produced from 1986 through 1992. Output was 190-204 hp (142-152 kW) at 6000 rpm and 185-196 ft·lbf (250-265 Nm) at 4800 rpm.
![Beach :beach:](./images/smilies/beach.gif)
- Gunta
- Real Name: Mark
You are a 100% correct there. A 2.7 only makes about 67kw on the wheels. Mine is stock standard with branches and balanced motor. I replaced my gas flowed head with a good spare I had as the other one was getting a bit thin and was not in great condition. So I went for reliability. I must add that it was pumping out 82kw with the gas flowed head and runing a Dictator and the same with the Gotech. So I am pretty pleased that it is running the same with standard management and head. The balancing must have made a difference as well. She has never been this smooth, and there is heaps of torque.
- Cres
- Town: JHB
- Vehicle: Cressida 2JZ , Lexus IS200 Sport , Hilux s/c 3.0D4D 4x4, Hilux d/c SFA 7MGTE
I know that dyno it doesn't give free power that is very good power congrats. You can add another 5-10kw if you go to another dyno.
- Rooies
- Town: Strand
- Vehicle: 1994 2.4i (22RE) D/C Raider 4X4
- Real Name: Rudi
You guys have me coinfused now. Do you want to tell me that my dyno reading isnt accurate. Ou ROOIES have done 162 000km not bad for a 1994 2.4 (22R). He is still stock standard besides the Brospeed branch & powerflow exhaust. According to the book he should have 80Kw & 183 Nm. I also average between 7.2km/lt and 7.4km/lt. Filled up yesterday and got 7.35km/lt. Speedo almost 100% correct.
![Image](http://i884.photobucket.com/albums/ac45/rooies/4X4/ROOIESDYNO.jpg)
ROOIES: 1994 2.4i (22RE) Raider D/C - 200 000kms - Brospeed Branch & Powerflow Exhaust
MIKEM Suspension & Gabriel Safari Shocks - "31 BF Goodrich AT - GOMAD Aluminium Canopy
Melvill & Moon Seat Covers - Safari Snorkel - Bushwakka Weekender Offroad Trailer
![Image](http://i884.photobucket.com/albums/ac45/rooies/4X4/Rooies.jpg)
- Gunta
- Real Name: Mark
Hi Rudi, 82kw is on the flywheel. A 2.4 pushes in the region of 49kw on the wheels and whith a gas flowed head and branches around 60kw on the wheels.
- kfxnando
- Town: Germiston
dont meant to start any thing however this is where the issues with dynos start!!Cres wrote:I know that dyno it doesn't give free power that is very good power congrats. You can add another 5-10kw if you go to another dyno.
what is the point to go to another dyno to get another 5-10kw!!
you wont be getting that 5-10kw, all you will be getting is a BS number to fool your self and your friends!!
a dyno can NOT give you extra power!! a dyno is a tuning tool!! it can not create power that is not there to start off with!!
again one needs to ware of the dyno operator!! hence why there are VERY few dyno operators that I trust!!!Rooies wrote:You guys have me coinfused now. Do you want to tell me that my dyno reading isnt accurate. Ou ROOIES have done 162 000km not bad for a 1994 2.4 (22R). He is still stock standard besides the Brospeed branch & powerflow exhaust. According to the book he should have 80Kw & 183 Nm. I also average between 7.2km/lt and 7.4km/lt. Filled up yesterday and got 7.35km/lt. Speedo almost 100% correct.
best is to rather stick to what gets to the wheels and not start to add compensation numbers for temp air pressure and transmission looses!!
the dyno operator does not know the condition of the box transfer case or diff to be able to add the correct correction factors!!
think you are at sea level!! (dyno chart details also indicate)
and if you say according to the book then that will be at the flywheel
so lets go through the same exercise as earlier!!
80kw - 39%(general loss for a 4x4)
=48.8kw on the wheels!!
Gunta points to 82kw - 39% =50kw
numbers close enough
dont know these vehicles so going on what I read here!!
then free up the breathing with branches and presume full low back pressure exhaust system a head job and the 60kw sounds pretty on the money!!
think of it this way that is a 20% increase in power!! that is very noticeable when driving!!
so lets work on a nice round number of 50Kw on the wheels!!
presume that those vehicles did not have cats in the system
so with a nice set of branches and full system, would say between 10-12 %
that would take the numbers to 55-56kw
if you think that is bad go look and see what My 3.4 has at altitude!!
enjoy!!
- Gunta
- Real Name: Mark
Fernando, what is your 3.4 pushing?
- kfxnando
- Town: Germiston
sadly not sure!!Gunta wrote:Fernando, what is your 3.4 pushing?
can only estimate!!
had a oil leak, and dyno operator would of chased me out if I had peed oil all over the show!!
oil leaking fixed, however not going to bother as the 3.4 is coming out soon to start the Lexus conversions!!
can however work on this!!
my sierra 3.0 went from 76rwhp to 108rwhp!! original 103kw flywheel after mods around 147kw
with motor overhaul, cam branches exhaust and a porting job by me, kept original compression!!
using the numbers that me has been discussing all the numbers work out, witch ever way one looks at it!!
so looking at the 3.4
it now has a cam, when I pulled the motor out and did seals and gaskets and recon stock heads . . . . . . .
stock 108kw - 39% loos (4x4) = 65.88kw RW will work with 66kw
66kw then to altitude 54kw RW
add branches and exhaust (dual 57mm right through) will still use the 12% gain although it could be more = 60.48kw RW
add cam its a Lamco 79(yep he is still around have his contact details) lets say 8% gain 65.3kw on the wheels!!
about 87.5RWHP
now me know that these numbers are out!! as the 3.4l is detuned out the factory, long story to post here
follow the link for more info http://www.kfxnando.com/viewtopic.php?f ... c6a1537979" onclick="window.open(this.href);return false;
so the cam would of made a bigger then normal difference!!
and it sounds so sweet now!!
would however say that the 54kw at altitude at the wheels would be pretty accurate
where in Johannesburg are you??
- Gunta
- Real Name: Mark
My office is in Bryanston, but I live out near Lanseria in Doornrandje.
- Cres
- Town: JHB
dont meant to start any thing however this is where the issues with dynos start!!kfxnando wrote:Cres wrote:I know that dyno it doesn't give free power that is very good power congrats. You can add another 5-10kw if you go to another dyno.
Hi Fernando i didnt say you will get more power all i said that dyno is a bit selfish on power readings if you make good power on that dyno your car is strong. Oh BTW bme dyno is a brake dyno.
- Gunta
- Real Name: Mark
Oh BTW bme dyno is a brake dyno.[/quote]
Whats the difference?
- Cres
- Town: JHB
It gets tuned under load and not inertia
Maar my vraag is hoekom sal mens nou in jou engine wil hardloop? Jy gaan probably jou kop stamp as jy dit try ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
- Gunta
- Real Name: Mark
What is the object of that and what is the benefit?Cres wrote:It gets tuned under load and not inertia
- kfxnando
- Town: Germiston
hi Mark
well at least you are not too far from the dyno that I have used and grown to trust!! he is in Brackpan, however you dyno operator seems to be fine!!
then on the inertia dyno, it uses accelaration times to work out power, from my experiance they are what I call happy dynos, meaning they give bigger numbers then reality!!
had my bikes on inertia dyno and got happy numbers that I know are not real!! my experiance!!
a break dyno, physically brakes the rollers that the car is turning to simulate road load conditions!!
with a load dyno, the dyno operator can hold at a certain revs and step it up to chech it all out in steps!!
need to go will post some later!! at work still!!
- Gunta
- Real Name: Mark
When I had my factory in Brakpan in 1990, I used 2 guys at the time, Sabie Coetzee and Clive Wesson. Sabie is still there almost 20yrs later.
- kfxnando
- Town: Germiston
yep, Sabie is the one that I have used for almost 20 years, yep pretty close to 20 years!!Gunta wrote:When I had my factory in Brakpan in 1990, I used 2 guys at the time, Sabie Coetzee and Clive Wesson. Sabie is still there almost 20yrs later.
those were the days, the days when the guys would come from Durban to dyno their cars by Sabie!!
the days when we would take our cars for a dyno and by early evenings the wifes were phoning the hospitals couz we were so into chit chat at "nitro performance" and the wifes though that we had wraped the cars around a pole or something!!
![LOL :lmao:](./images/smilies/laughingneqw.gif)
no cell phones those days!!!! HeeeeHA!
Sabie is a great guy, and always willing to help and straight forward!! and me very much trust his dyno numbers!!
for some reason have not forgotten his number!!
011 740 1330
those days used to have a 2.8GTX skyline with 210RWHP for those days it was FAST!! and even today its enough to hand it out to the M3 boys!!
for the cherry on the cake, he got that Datson 1200 to 8.6sec 1/4mile time with a Ford V6
and for the Toyota guys that same vehicle is now getting(should be done by now) a 7GM if me dont have the motors confused!!
that would be the straight 6 with turbo and Nos!!
last point, his dyno is a load dyno!!
me need to go visit there again!! soon!!
- Gunta
- Real Name: Mark
I had a golf 16v bored to 2l and stroked to 2.1l with solid lifters. It was pumoing out 110kw on the wheels for a normally asperated motor back in 95. I miss that golf ![Beg :beg:](./images/smilies/beg.gif)
- kfxnando
- Town: Germiston
can believe that you miss it!!
the only thing fast that I have had for a long time has been the bike!! however that is different!!
mow with the jeep, often wonder how did I ever live with out the extra power!!
now there is a big itch all over again to build something again!!
and the plans could change all over again!!! eish!!
- Gunta
- Real Name: Mark
My next project is going to involve a 427cu V8 ![Boss :boss:](./images/smilies/big_boss.gif)
- Vehicle: 2018 FJ Cruiser
'n volle 7 liter??
![Shocked :shock:](./images/smilies/icon_eek.gif)
email: thysdj@gmail.com
- Gunta
- Real Name: Mark
Thats the one, there's no substitute for cubes.
Tell VW that..
What are you going to drop the big block into? :wink2:
- Gunta
- Real Name: Mark
The old Ford F250 4x4
So ja! That will work well..
- Gunta
- Real Name: Mark
My last F250 had the 351cu which I sold in 97. I am itching to do another one again but a big foot.
What mods are you going to make to the 427?
- Gunta
- Real Name: Mark
Edelbrock manifolds and a 750 double barrel Holley carb, balanced motor. I have even been toying with the idea of putting that motor in a 80 series cruiser.
Cool stuff. I want to do my Chevy 350 like that too, except I am going to EFI it with a multicoil setup... Already got most of the parts including the Edelbrock intake manifold.
An 80 series would be awesome with that motor, add suckers to the tyres and youll be able to drive up sky-skrapers..
- Gunta
- Real Name: Mark
Thats exactly what I had in mind. The 80 series is a machine with awesome articulation and with 2 lockers it should be unstoppable.
That would be my ultimate vehicle. I just need to find a decent cruiser now.
A few months ago I assisted Hoppy road tuning a Cruiser(60 series IIRC)... newly fitted with a fuel injected chev LT1 engine... from the Z28 camaro...
That's one awesome engine, I never knew a chev 5.7L could rev so freely... with 220kw on tap, the heavy cruiser body was propelled around like a lightweight gokart! Lekker!
What was the torque figures on that motor B? ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Thys, I'm not entirely sure which generation LT1 is was, here are the stats from WikiPedia:
The 1992 LT1 in the Y-body was factory rated at 300 hp (220 kW) and 330 lb·ft (447 N·m). 96 LT1 Y-bodies were rated at 300 hp (220 kW) and 340 lb·ft (461 N·m). The 93-95 F-bodies were rated at 275 horsepower (205 kW) and 325 lb·ft (441 N·m), while the 96-97 cars were rated at 285 horsepower (213 kW) and 335 lb·ft (454 N·m). The 96-97 WS6 and SS F-bodies were rated at 305 hp (227 kW). The 94-96 B and D-body version was rated at 260 horsepower (190 kW) and 330 lb·ft (447 N·m).
Whichever one is was, it was alot more powerful than the Lexus V8, my gut feel is that it could have been the 220kw - 447nm version.
powerful stuff... but the sound is all I am interested in really...
Then Thys... this video clip was made for you:
http://www.metacafe.com/watch/339596/to ... v8_sounds/" onclick="window.open(this.href);return false;
awesome...
MTFBWY!ThysdJ wrote:awesome...![]()
AWY2 ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
- Gunta
- Real Name: Mark
What management system did you use?
IIRC a Dicktator, the advanced unit... worked flipping well... yes even I was surprised...
- Gunta
- Real Name: Mark
With the dictator I am sure he is doing 2km/l
I'm running a Dicktator, get around 7.5km/l... what's wrong with the Dicktator in terms of fuel consumption?
- Gunta
- Real Name: Mark
Running a std Dictator in my 7mge I got 5.2km/l so I was wondering what you would get with a V8. I get almost 7km/l with original ecu after I took out the Dictator.
- Kaspaas
- Town: Wellington
- Vehicle: 1998 Land Cruiser 105series GX
- Real Name: Cobus
Interesting facts Mark!
