IFS Front Recovery Point??
- warrenaken
- Town: JHB
- Vehicle: 3.0 KZ-TE 4x4
- Real Name: warren
- Club VHF Licence: X04
Hi All,
I have for some time been trying to get decent front recovery point on the front of my KZTE. As i have the Intercooler and hi-lift jack points space is limited. Everyone i have been to has said a replacement bumper is the only option, so i need your help.
Currently i sit with 2 plans, please could you comment or suggest other options. Much appreciated.
Option 1: Make sure the nudge bar is bolted on with high tensile bolts (blue) and the bolt recovery hooks onto the side of the nudge bar bracket.
Option 2: get a frontrunner type recovery point (just longer) and bolt it directly to the chassis between the nudgebar mounting. I would need to cut a small portion of the white bumper if it is to remain straight.
Option 3: your suggestions?
Toyota Hilux KZ-TE
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: IFS Front Recovery Point??
Warren
All new IFS vehicle's from Toyota had a recovery hook in the same place as your option one. The only difference is that it was fitted with the hook facing downwards and was bolted to directly to the chassis over the nudge bar bracket.
This is the way I will opt to go as I was standard fitment. Maybe some IFS owner with the STD front end can post a picture for you to see.
- Spartan
- Town: Vanderbijlpark
Bout hom net aan die anderkant vas, of verskil die gate
MOBILITATE VINCERE
Spartan
Spartan
Ek sou opt vir opsie twee. Jy wil graag he dat die recovery punt direk op die chassis is
option 2
- warrenaken
- Town: JHB
- Real Name: warren
Thanks guys, i prefer option 2 as well. Will have to speak to the engeneering guys, but maybe something like this:
Toyota Hilux KZ-TE
Perfect. You can make it shorter as well. It does not need to protrude part the bumper as long as it is lower than the bumper
Warren, you going to put one on either side?
- warrenaken
- Town: JHB
- Real Name: warren
Yes and then i will use a bridal as i do at the back.
Thanks for the replys.
Toyota Hilux KZ-TE
- Okkie Van Wyk
- Town: Middelburg
- Vehicle: 2011 Hilux 3.0 D4D D/C
- Real Name: Okkie
- Club VHF Licence: N019
Hi you all
I have pondered on this subject for quite a while now and came up with a solution for my front recovery point problem. I integrated it as part of my winch bucket , had to do some re modeling of the winch bucket but it came out quite good and practical (Still have to do some final maintenance on the winch before putting it all back)
Look at the photos and give me your thoughts
The idea is to use both hooks simultaneously with a short brace
123 WEG MP
2011 Hilux Vigo 3.0 D4D D/C
VENI VICI VIDI
CAME, I SAW, I CONQUERED
VENI VICI VIDI
- Spartan
Okkie dit is regtig netjies gedoen maar nou gaan jy teen n hoek trek wat stress op plekke sit wat nie so sharp is nie, persoonlik so ek die hakke reguit voorentoe laat kyk het. M2cw
MOBILITATE VINCERE
Spartan
Spartan
- HiluxJunkie
- Town: Middelburg MP
- Vehicle: 2001 Hilux DC 4x4 2.7i Raider
- Real Name: Simon
- Club VHF Licence: N15
Behoort nie 'n probleem te wees as hy 'n bridal gebruik wat se hoek in lyn is met die plat oppervlak is waar hak vasbout.Spartan wrote:Okkie dit is regtig netjies gedoen maar nou gaan jy teen n hoek trek wat stress op plekke sit wat nie so sharp is nie, persoonlik so ek die hakke reguit voorentoe laat kyk het. M2cw
Lyk shanana Okkie
Jaco, ek dink die rede waarom dit so gedoen is on rede die nudge bar in die pad is.
Okkie , sal so iets nie werk nie (my kennis van drawing is nou nie so hot nie, so verskoon maar)
- 20082010005_resize.jpg (25.22 KiB) Viewed 3109 times
- Spartan
Ek verstaan maar as jy kyk na waar al die stress geplaas word is die opset vir my nie veilig nie, en die is net my opinion, dit lyk baie nice maar vertrou nie daai hoek nie, maar dit is ook nie myne nie, elke brommer op sy eie HiluxOOOOMS wrote:Jaco, ek dink die rede waarom dit so gedoen is on rede die nudge bar in die pad is.
MOBILITATE VINCERE
Spartan
Spartan
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Ek het sommer die armgat manier gegaan en 2 gatte in my budge bar bracket geboor. een aan elke kant. Druk sommer die D-Shackels daar deur. Lyk miskien nie si impressive soos `n recovery hook nie. maar het my R250 gespaar.
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Okkie dit lyk vir my sterk genoeg as die bracket dit sal hou.Hoe dik is die materiaal waar die bracket vas maak?
Warren,ek sal ook gaan vir opsie 2.
- Okkie Van Wyk
- Town: Middelburg
- Real Name: Okkie
The idea is to use both the hooks at the same time, connecting a short bridle end to end to the hooks forming a triangle inline with the hooks normal pulling line thus utilizing the strength of both hooks
The sides that bolt to the chassis are 6mm and the back plate that bolt to the cross beam is 8mm thick.123 WEG MP
VENI VICI VIDI
VENI VICI VIDI
- Spartan
Ok dit klink reg vir myOkkie Van Wyk wrote:The idea is to use both the hooks at the same time
MOBILITATE VINCERE
Spartan
Spartan
- Okkie Van Wyk
- Town: Middelburg
- Real Name: Okkie
At last and if I may say so a job well done
All that’s left now is to test the "VLAKVARK" teeth and see how they perform PS.
Now I have to make a plan at the back as there are no recovery points at the back yet
any suggestions from you people ?
123 WEG MP
VENI VICI VIDI
VENI VICI VIDI
Baie nice Okkie
How looks your Vlakvark's tail? Show us the tow-bar then we can have a look at a solution..
- warrenaken
- Town: JHB
- Real Name: warren
Okkie, nice winch plate
I have had 2 cruiser points bolted and welded onto the back bumper as well as the bumper itself reinforced onto the chassis. Used with a bridal it had done some tough work.
Toyota Hilux KZ-TE
