radiator leak
WayneMan
Town: Joburg
Vehicle: Toyota Hilux KZTE 4x4 DC
Real Name: Wayne
radiator leak
Post by WayneMan »
What causes a radiator to leak?
i cant see specifically why its leaking, buts it leaking from somewhere near the top coener. its 2005 KZTE. it was replaced with a new unit from Toyota in about 2014.
Sent from my SM-A705FN using Tapatalk
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Re: radiator leak
Post by The Legend »
WayneMan wrote: Sun Feb 07, 2021 10:29 pm What causes a radiator to leak?
It might be high water pressure in system? When did you last check your radiator cap?
WayneMan
Town: Joburg
Real Name: Wayne
Re: radiator leak
Post by WayneMan »
cap is fine.
Re: radiator leak
Post by Thabogrobler »
Cracked head pushing pressure into the cooling system?
Bear
Town: Johannesburg
Real Name: Ricky
Re: radiator leak
Post by Bear »
It's difficult to say why it is leaking. If no or low antifreeze is in the system it will rust and cause a leak.
Take it to a radiator shop and ask for a free quote on repairs. They will tell you the fault.
To make out a head problem, cracked or blown gasket open the radiator cap when cold and start the vehicle, it will through water out the radiator while the engine is still cold.
