Hello all.
I have purchased a new set of LED fog lamps that I’m fitting into a custom bumper.
I want to use the current wiring and switch within the vehicle. Just makes sense.
My concern however is that the original wiring is a smaller gauge than what the new fog lights have.
I don’t know what the watts are on the new lights either.
Am I taking a chance using the existing wiring and switch?
Thanks.
New fog lamps and old wiring?
Re: New fog lamps and old wiring?
I think the LED's will draw less than the original incandescent lamps so you should be fine with the old wiring. If you're really concerned, use the original wiring to operate a relay and wire the lamps direct to the battery with an in-line fuse and heavier gauge wiring. That's the route I would go anyway because there is no significant voltage drop and the lamps will be a little brighter.
- bullit
- Town: Johannesberg
- Vehicle: Toyota Hilux
- Real Name: Ryan
Thanks.
I didn’t think of that actually.
Il have to figure the wiring out.
What are the specs on the new spots?
- bullit
- Real Name: Ryan
I don’t know what the specs are for the new fog lights. That’s one of my issues.
Do they give the wattage?
- bullit
- Real Name: Ryan
no nothing on the spotlight or the box they came in.
Try doing a search on the product and see what comes up. They would normally list specs and give either the wattage or the power consumption / draw.
- bullit
- Real Name: Ryan
If I put my multimeter on 20A setting I read 0,71
VxA=W
Would these spots not be give or take 80 watts
I may be way off though I’m not an electrician.
VxA=W
