HI all
Need some advice, got a 1998 LTD SFA with a 22R. Previous owner put in a new radiator but it seems it is leaking. Rather than repairing I want to replace with new. Spoke to my local CHE(Cape Heat Exchange) and they recommended building a copper radiator for around R3500.00 installed. It will be bigger and taller, and according to them much better than what I have now.
What do you guys suggest, go with the copper one or replace with aluminium? If aluminium what type? I remember reading somewhere that the BMW 740 radiator fits. Don't mind spending R3500 but want to know that it will be a permanent fix, but if I can get away with less even better.
Thanks in advance.
Leaking Radiator
Re: Leaking Radiator
Just go for the standard alu radiator (about R900) .... It'll work as well if not better than a copper one. Witha standard radiator you can still use your existing cowl, whereas with a larger custom unit you would have to have a new cowl made up .... more $$ that they will be stinging you for!! The guys at Toyota with the thick coke-bottle glasses and white coats would have designed a bigger radiator if it was required.
What engine do you have in?
We had this discussion on the Tazz thread the other day. Aluminium is better for heat transfer.
It's a 22R Pieter, so no conversion that requires more cooling.Need some advice, got a 1998 LTD SFA with a 22R.
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
agree with Andy. I had a 4 core copper radiator in my bakkie with Kzte and had heating problems. change to standard kzte aluminium radiator for R1200 and problem was solved.
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
The 2.7 aluminium radiator from Gemini Spares in Brackenfell will fit straight in and will do the trick. R 900 IIRC.
- Vehicle: Lumina
- Real Name: Nicholas
Thanks for the feedback guys! Always a wealth of knowledge here.
Anymore input/experience always appreciated
Replace the thermostat while the coolant is drained.
- Vehicle: Lumina
Leaking Radiator
Spoke to Allen and Francois, they recommended the 2.4D radiator as it has a thicker core but it is a bolt on fit and requires no modification. Will ask Francois to change thermostat as well.
Thanks for the advice all!
