Snorkel
warn winch
rear diff lock
Long range tank
Gomad Canopy
Whats still to come:
In the long run would like to fit 1uz-fe lexus
35 tyres
what i'm busy with:
i went swiming on the weekend with my lux and water came in through the door and all my carpets got wet
![Blushing :blushing:](./images/smilies/blush2.gif)
so i've taken all the carpets out and hung hem up to dry, thinking about ruberising inside because this is bound to happen again
![Thinking :think:](./images/smilies/icon_think.gif)
100 mm rectangular channel on top of diff and have longer u-bolts, brake pipes and shock mounts.
50mm extended grease able shackles.
50mm body lift, which will also help when i fit the lexus
i also want to change the diff ratios so that i will be able to run 35's with the lexus.
but carry on with the 2.8D and the 31's for now. won't matter if i have a lot of power and not much speed for now. what would be the right diff ratio's? also would like to keep local diff in the rear.
an issue with the suspenton lift what plan can one make with this steering arm arm? as it will be too low now? all comments and advice is welcome
