Hilux Vigo V6 - Engine Noise After Decat
Hi All,
When I purchased my bakkie the cats had already been removed. Of course I did enjoy the enhanced performance and deeper exhaust note! But with these benefits came a distinct increase in engine noise. According to the guys from PowerFlow and Hoppy this is not unusual when the exhaust is decat'd. Still, I've always felt that the exhaust header noise(sounds almost like a blown exhaust manifold) was just too loud. Hoppy serviced the bakkie which made a huge difference, but still I wasn't totally happy... then Hoppy mentioned that on the IFS 2.7's the steering column firewall seal is known to perish and collapse, which allows alot of engine noise into the cabin. A few days later I decided to investigate and low and behold I found this:
The steering column hole is right by the 'empty' catalytic converter box, so that exhaust noise I've hearing has been coming from here all along!
To be continued... (shortly)
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Re: Hilux Vigo V6 - Engine Noise After Decat
Hi Mr B.Glad you are still alive
One can listen to The Hilux Whisperer
- TOYODA
- Vehicle: '89 YN67R with Ford V6 3.0
- Real Name: Tiaan
Thanks Bretton
I'm going to check mine tomorrow...
Ok, so I knew what the issue was... now the remedy. The original seal is integrated with the mounting plate that holds it in place, this Toyota sells as a single unit and I didn't even bother finding out what it costs... probably lots of moola. Anywho... I felt that the OEM seal was pretty flimsy, and it'll probably tear/perish soon again, especially seen as it's so close to the exhaust. So I decided to upgrade the fix!
First I had to remove the mounting plate. This entails removing the 3 nuts that hold the plate down, then loosening the steering column clamp on the engine bay side, 2 bolts. It's up close to the firewall... note that you must totally remove the bolts(else it won't come loose) which allows the clamp to slide up and disconnects the 'cab-side' steering column from the 'engine-side' column. Then under the steering wheel you need to loosen another steering column clamp, above the vibration damper and universal joint. With this section out the way the mounting plate can be removed... pics:
Then I used a universal CV joint and a 5mm thick off-cut of rubber mat... and made my own seal/ column boot:
I cut off the largest ring of the CV boot and used RTV 6999 grey gasket maker to seal the boot again the mounting plate... I didn't have any Slicka Flex... so the gasket maker had to do! It's a perfect fit!
Then I inserted the 5mm rubber disc, with the OEM foam rings for added sound damping... note that the steering column hole is off-centre...
Slipped the boot back over the steering column... and then re-assembled everything... ta-da... finished...
So that's it... it's much stronger than the OEM part, and the noise is gone! And the whole job cost me just over R100 (1 x CV Boot)!
- Town: grassy park cape town
- Vehicle: 99 s/c hilux 4x4 2.7i long range tank & dual battery; 2003 nissan x-TRAIL (4X4)
- Real Name: charl
nice :!: very innovative (creative) must say ,so much to learn on this forum
![Dance1 :dance1:](./images/smilies/dance2.gif)
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Nice, I like this approach! Good job
Sifu-Lux....I will miss you
- Danman
- Vehicle: 2009 Fortuner 4.0 V6 aka "BosBuffel"
- Real Name: Danie
Didn't know this was an issue on the IFS,
Thanx Bretton and Allen, I've booked this weekend as TLC weekend for "Noster", this will be added on the list.
Bretton.... those pictures of the mounting plate (fitted)... are they taken inside the engine bay or from inside the cab?
Inside the cab Cassie. Do you want a pic from the other side?
Thank you sir... no... not necessary... was just trying to get my head around the setupMr_B wrote:Inside the cab Cassie. Do you want a pic from the other side?
![Big Grin :D:](./images/smilies/icon_e_biggrin.gif)
![Waving :wave:](./images/smilies/icon_wave.gif)
One serious warning on this job. Whilst the steeing column is disconnected, do not spin the steering wheel around at all, as I did. There is an electrical contraption between the steering wheel and steering column. This goody interconnects the hooter and airbag on the steering wheel to the rest of the electrical system, while allowing the steering wheel to turn normally. If you spin the wheel too many turns, the thin flat link cable gets torn from it's connection points, which obviously kills the hooter and airbag. I tried to repair it carefully this morning, but alas it tore again as soon as I turned the steering wheel from side to side.
So save yourself some frustration and don't spin the steering wheel... wonder what the replacement part is going to cost???
:evil:
:evil:
Very good idea Mr B
Me had the same on me Lux. Had it at Speedy 20 times to look for exhaust leak before we realised that it is that rubber.
(Some fellow Luxer at Hoppy's place told me to look at that rubber, don't know you but thanx for the advice)
I was too lazy to do the whole fix like you, a boer maak a plan.
So I sommer cut two pieces of leather in a round shape, with opening and used Genkem to glue the one on the cab side and the other on the engine bay side. The hole is so big the two pieces are also stuck together.
Worked like a charm, took ten minutes and it makes a HUGE difference. Da Lux is now very quiet and feels like a new one.
If your Lux is a bit noisy in the cab, I suggest you look under the dash and see if your rubber is not broken.
I think one day when I am bored I will change to the Mr B type of rubber, is a more permanent solution.
![Clapping :clap:](./images/smilies/icon_clap.gif)
![Image](http://www.4x4direct.co.za/4x4direct-comm.jpg)
By the way, Mr B, those coil looms are very expensive, so good luck on that one.
- louis fourie
- Club VHF Licence: X101
Dankie ouens. Nou weet ek waar die geraas vandaan kom. Daar kom ook heelwat water in as jy vinnig deut 'n plas water ry
Sent from my GT-I9300 using Tapatalk 4
Nou's ek die... :evil:pietpetoors wrote:By the way, Mr B, those coil looms are very expensive, so good luck on that one.
- louis fourie
Yip. Nou net gaan kyk. Myne se rubber het ook omtrent heeltemal gedisintegreer. Raai wat is my volgende projektjie:Dlouis fourie wrote:Dankie ouens. Nou weet ek waar die geraas vandaan kom. Daar kom ook heelwat water in as jy vinnig deur 'n plas water ry
- Toppie4x4
- Town: Centurion
- Real Name: Andre
wow and this is exactly what wrong with my lux as well.....................luckily I read this tread before going to an exhaust place.
