I'm hearing that the Fortuners are permanent 4wd and its only low range thats engaged manually
Is this true?
Fortuner - permanent 4wd?
- Town: Midrand
- Real Name: Nishan
Real drivers use three pedals
Re: Fortuner - permanent 4wd?
Full time 4x4, only low range and the center differential are engaged manually.Die$eL wrote:I'm hearing that the Fortuners are permanent 4wd and its only low range thats engaged manually
Is this true?
- Jaco Versfeld
- Town: Western Cape
- Real Name: Jaco
- Club VHF Licence: X69
Does the Fortuner have the same gearbox and centre diff as the Prado?
What is the Prado's centre diff called again, think it does a 40/60 split if it is not locked...
ThysdJ wrote:Full time 4x4, only low range and the center differential are engaged manually.Die$eL wrote:I'm hearing that the Fortuners are permanent 4wd and its only low range thats engaged manually
Is this true?
- Optimus Prime
- Town: Krp
- Vehicle: Fortuner 4.0 v6
- Real Name: Robert
Does anyone have pics of the gear lever ,what it says on the lever?
mine looks like this ,is this what you talking about.
says LL
N
HL and
H
says LL
N
HL and
H
- Attachments
- (56.94 KiB) Downloaded 105 times
"As long as power flows through any of my circuits ill 4x4."
- Johan Havenga
- Town: Heidelberg Gauteng
- Vehicle: Toyota Prado 120 V6
The 4x4 Condor models as well!
You engage Centre Diff Lock H & L with short lever!
Low Lock(locked centre diff)
Neutral(well, neutral!)
High Lock(locked centre diff)
High(Open centre diff)
