What are the reasons an engine would miss fire
Post by CasKru »
I'm busy diagnosing the reason why my daily runner has an irritating miss.
To my knowledge there are basically 5 reasons a car would miss:
1) faulty plug leads / coil lead
2) faulty dizzy cap
3) faulty rotor / points
4) Ecu mapping
5) faulty plugs
I have replaced the plug leads thinking it could be the problem but this seems to have make it worse to some extend. The dizzy is also not what I am used to as it has a box shaped dizzy with the plug leads connecting in a straight line. So I'm guessing I have to do with something different than a rotor and points.
It's a Kia Picanto. I took this photo when I installed the new plug leads to fit them in the correct order again
Re: What are the reasons an engine would miss fire
Post by pietpetoors »
And da plugs, start with da plugs they are the cheapest, I had a set which only did 2,000km on the Hilux and then one plug started giving problems
Post by CasKru »
pietpetoors wrote:And da plugs, start with da plugs they are the cheapest, I had a set which only did 2,000km on the Hilux and then one plug started giving problems
Die outjie moet oor 3000km nuwe timing belt kry en service. Het gedink ek sal dit sommer dan doen. Thanks
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Another less common fault causing misfires is a faulty injector, which leads to air/fuel mix running lean on that particular cylinder. Others I can think if... intake manifold leaking, exhaust mani leaking, maybe a sticky valve... overheating coil pack, dirty or contaminated fuel...
Post by CasKru »
Thanks B.
Will check those.
Bulletjie-3
Real Name: Everdt
Post by Bulletjie-3 »
When the engine is hot or cold ?
Post by CasKru »
Bulletjie-3 wrote:When the engine is hot or cold ?
Both but would say it's more pronounced when hot
Do a compression test to diagnose or rule out internal mechanical faults like the valves and rings. Would also look at injectors and mapping if it's EFI. Plugs and leads are the most common causes next to cracked dizzy caps.
Good luck! ;-)
Post by CasKru »
Mud Dog wrote:Do a compression test to diagnose or rule out internal mechanical faults like the valves and rings. Would also look at injectors and mapping if it's EFI. Plugs and leads are the most common causes next to cracked dizzy caps.
Good luck! ;-)
Thanks... will do :thumbup: :thumbup:
Bulletjie-3
Real Name: Everdt
Check if the sparkplugs aren't cracked.
Post by CasKru »
Bulletjie-3 wrote:Check if the sparkplugs aren't cracked.
Sal so maak dankie. Wil ook sommer 'n gap check :thumbup:
Doom
Town: Windhoek
Vehicle: '92 Hilux 2.2 DC 4x4 - "Boetman"; '96 Toyota Hilux 4x4 - Lexus, 98 Toyota Hilux 2.4 4x4
Real Name: Willem
Post by Doom »
Het sy teleskoop nie dalk gestamp nie? Agter gekom dis die mees waarskynlike rede vir 'n miss fire? :angel: :angel: :D:
LOS MAAR DIE KAAS, GENIET DIT NET !!
Post by CasKru »
Doom wrote:Het sy teleskoop nie dalk gestamp nie? Agter gekom dis die mees waarskynlike rede vir 'n miss fire? :angel: :angel: :D:
:mocking: :mocking:
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Ek sien hy het 2 coils en werk op wasted spark. 2 pistons kry gelyktydig vuur. Maak seker die pickups is skoon. Hulle sit gewoonlik op die cam, volg net die drade van die coil af. Kan dalk ook n sticky valve wees. Gaan ook jou vacuum pype na dat hulle nie geperish is nie, anders sal die vacuum advance nie reg wek nie.
Post by CasKru »
Vlak vark wrote:Ek sien hy het 2 coils en werk op wasted spark. 2 pistons kry gelyktydig vuur. Maak seker die pickups is skoon. Hulle sit gewoonlik op die cam, volg net die drade van die coil af. Kan dalk ook n sticky valve wees. Gaan ook jou vacuum pype na dat hulle nie geperish is nie, anders sal die vacuum advance nie reg wek nie.
Dankie :thumbup:
Het darem al uit gevind waar sit die cam sensor so weet darem waar om vir hom te gaan soek :thumbup:
Hilux 1
Real Name: Tertius
Club VHF Licence: HC137
Post by Hilux 1 »
dalk daai swem deur die bad? bietjie water gekry waar hy nie moes nie?
Hilux 1 wrote:dalk daai swem deur die bad? bietjie water gekry waar hy nie moes nie?
Dis nie die Hilux nie ....
Post by CasKru »
Ja nee... die Hilux het nog nie 'n beat gemis in die 4 of wat jaar wat ek hom het nie :thumbup: :thumbup: (behalwe nou toe die dizzy bietjie water in gekry het)
LouisZ
Post by LouisZ »
Het jy reggekom met Hilux? Sal die Kia ook 'n Lamda of knock sensor he? Hulle se ook kyk na die Crank sensor, ook die coil pack toets
Post by CasKru »
4x4megaworldpta wrote:Het jy reggekom met Hilux? Sal die Kia ook 'n Lamda of knock sensor he? Hulle se ook kyk na die Crank sensor, ook die coil pack toets
Al die goed is geskeduleer vir die naweek. Sal maar sien by hoeveel van dit kom ek uit
Post by CasKru »
Okay... net so vinnige feedback... weet julle sit al meer as 'n maand lank op die punte van julle stoele om te hoor wat gaan hier aan... hehe
Laas week toe slaan die kilos mos nou oor na die 90K toe. Koop toe al die diens parte en timing belt met sy tensioner.
Saterdag vervang ek toe die timing belt en tensioner, doen 'n full service (Al die filters, spark plugs en olie). Toe ek hom daar opstart toe klink hy somer weer beter. Ek gaan lees toe bietjie op KIA se forums en sien hulle reken die sparkplug gap is beter om hom tussen 0.030 en 0.032inch te stel. Gaan doen dit toe en nou loop hy al te mooi. Dankie vir almal se voorstelle en idees.
Nou wil ek sien of sy petrol verbruik verbeter van 18km/l af :twisted:
Cleaner
Town: Johannesburg
Vehicle: Toyota Hilux 4l V6 4x4 Auto
Real Name: Ernst
Club VHF Licence: X31
Post by Cleaner »
CasKru wrote:Nou wil ek sien of sy petrol verbruik verbeter van 18km/l af :twisted:
:shock: :o: :alvarin: :blink: :cry:
"Every loaf of bread is tragic story of grains that could've become beer, but didn't. - Walter Thornburgh"
"The best cure for Sea Sickness, is to sit under a tree. - Spike Milligan"
