Kzte pump
- jamiel
- Town: cape town
- Vehicle: toyota hilux kzte
- Real Name: jamiel
Kzte pump
Please advise...
Bought my 2000 kzte and the previous owner took electronic pump off and put machanical one on. Result is hi diesel consumption and no top end power. Where can i get new or recon pump for the bakkie would love it to operate at its optimal. Got few quotes but pumps all out of Cape town, then the plugs for the pump looks to be cut off.
Any advise would be apreciated.
Thanks in advance
Thanks in advance
May the light always shine.
- louis fourie
- Club VHF Licence: X101
Re: Kzte pump
Jamiel
I don't know where you will get it - I am in P-Town . You will also need an ECU. Hopefully they did not strip that out as well. It is behind your glovebox.
Hope you come right. You are going to pay a few moolas
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Kzte pump
You will have to source a donor vehicle at a scrap yard and buy the loom, ECU, alarm box, transponder and key out of the same vehicle.
The colt 2.8 mechanical pump is another option, an improvement on the 2L2T pump most people fit.
aev@iburst.co.za
Re: Kzte pump
I have a spare KZ pump - but I understand it is from the Prado and differs from the Hilux??? If you could get a Prado loom, then perhaps?
- SKRIK NIKS
- Town: krugersdorp
- Vehicle: hilux 3.0kzte
- Real Name: jan venter
Re: Kzte pump
i have a pump for you,when i replaced my engine en on the kz,the new engine came with a pump
pm me if you want it
SKRIK NIKS
- jamiel
- Town: cape town
- Real Name: jamiel
Kzte pump
Hi Skrik
Just curios did you crack the top of the old motor seems that is the problem with the Kzte motor?
Any advice from community to try and prevent that if the case, any mods maybe Sac conversion?
- SKRIK NIKS
- Town: krugersdorp
Re: Kzte pump
no,is stil have the complete engine,there was a small hole burned in to piston no 3,i am sure that it was over feuling
SKRIK NIKS
Re: Kzte pump
It bolts on, you just need to sort the electronicsjamiel wrote:Thabo would one not be able to modify that pump to fit kzte anybody got an idea?
- jamiel
- Town: cape town
- Real Name: jamiel
Kzte pump
Just found out my bakkie is a 3L e
with a Kzte motor fitted. Gearbox on bakkie now for 3 lit and not Kzte so the box packed up.
I'm stuck in Arniston at the moment anybody know where I can get my hands on a Kz box for bakkie?
Wanna put electronic pump on bakkie was told the 3lit d does not have the loom or ecu. Getting lil despondent now with everything, anybody know who would be able to do such mod if possible.
Many thank
Many thank
Re: Kzte pump
Those Kz boxes can be quite elusive!jamiel wrote:Just found out my bakkie is a 3L e
Many thank
- Hilux01
- Town: Secunda
- Vehicle: Toyota Hilux 3.0D4-D dc 4x4
- Real Name: Henk
- Club VHF Licence: X85
Re: Kzte pump
Jan,
Ek het jou n PM gestuur, self opsoek na n KZ-TE pomp
- SKRIK NIKS
- Town: krugersdorp
- SKRIK NIKS
- Town: krugersdorp
