mod to rear seat -vigo shape
- andrevt
- Town: sasolburg
- Vehicle: raider d4d
- Real Name: andre
hi luxes
for your intererest :you will notice from the photies that i have sawn off about 10 mm of the catch of the rear seat wich hook into the "bracket" at the rear of the cab,by doing this your rear seat can now fold up or down ,nice space is created now for speakers or any other goodies. it is perfect for your rifle as nobody will see it and it is not in your way
- Attachments
- IMG_0362 (Small).JPG (22.23 KiB) Viewed 40815 times
Toyota Hilux 3.0 D4D 4x4
Re: mod to rear seat -vigo shape
Clever!
- Royco
- Town: Stellenbosch
- Real Name: Roy
- Club VHF Licence: X88
Great idea, Andre.
I've been thinking about doing this, glad to see I'm not the only one who misses the rear seat fold DOWN!
But what keeps the seat upright now? Maybe I don't understand your mod, but in my mind, you've modified the bracket which keeps the seat in place??
Roy
Roy
- andrevt
- Town: sasolburg
- Real Name: andre
roy
i have only shorten the bracket it still hold the backrest in place you only need to lift the seat slightly up and the back rest unhook
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Andre, I have still not done mine (really want to), have you experienced any rattles or things like that?? (unlikely that it would)
Know what you don't know.
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
My backseat had a rattle on gravel roads, but I fixed it with a piece of a pool noodle. (This is with a standard bracket)
- Rieks
- Town: Outjo
- Vehicle: 3.0 D4D
- Real Name: Rian
Very clever - boer maak 'n plan.
My back seat rattles all the time. I have two little ones that still sits in their baby stools, and with the weight on the seat, it rattles constantly - It drives me nuts!! The moment the seat carries weight, it starts to rattle, even if the baby chairs are out. Does anyone have a solution? Where did you stick that pool noodle in?
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Mine also rattles the whole time? Any Ideas?
- Town: Springs
Dankie tog, ek is dankbaar myne raas nie.
- Fred79
- Town: Kent UK
- Vehicle: Toyota Hilux Icon 2.4
- Real Name: Frikkie
My agter sitplek rattles net as daar iemand op hom sit die res van die tyd is hy stil.
Dit maak my sommer die hoenders in elke keer as dit so raas.
- AM Racing
- Real Name: Dylan
Take a piece of 6mm fuel hose the length of the eye. Split it down the middle and slip it over the eye. Do this both sides. It can be a bit of a b1tch to get the hooks on the seat to go over initially. You will need to moer the seat down. I did mine 50000km ago and still keeping its mouth shut
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Dankie vir daai tip!!
- Royco
- Real Name: Roy
I have been thinking about turning the bracket, on the seat upright, upside down.
That way, when the lower seat part is down, the upright part is pushed UP and the seat is kept in place.
Then when the lower seat part is lifted, the upright moves DOWN and releases the seat from the bracket.
I think it's a perfect idea ... in theory!
Problem is - I can't get the bracket off the seat... what kind of "bolts" are these?
Is my only option to grind them off, and then possibly face a rattle problem?
- Town: Springs
Roy, that might be a bit risky, those are real rivets. I'd keep them in place.
Other option is getting a seat from a scrapyard and testing your theory.
- Royco
- Real Name: Roy
Thanks Heinrich.
I appreciate the wisdom!! (that's why i like this forum!)
You saved me a rattle ...
The job for this afternoon ... replace rear seat, and forget about the space behind.
Sorry Andre, I'm scared of your solution too.
- Lane
- Town: Port Shepstone - KZN
- Vehicle: 97 Hilux 2.4 D/C Raider
- Real Name: Lane
Father in law drives a 2006 d/c and his back seat used to do the same, when it went to toyota for a service he complained and they said they had a new part to repair the noise. im unsure of costs as they did it for free! :shifty: (seems it may be a factory fault or rather a very common problem). i never really checked what they did as its not my van.
- Town: Kyalami
- Real Name: Mike
Andre are you still happy with this mod?
Anyone else try this?
I am keen to do it but nervous about messing it up
Did mine is Dec....literally 15 mins.
Did another one a month ago, easy as pie! just need a 14 spanner and an angle grinder
- Town: Kyalami
- Real Name: Mike
How much do you cut off? My angle grinder is itching to go this afternoonOOOOMS wrote:Did mine is Dec....literally 15 mins.
You will have to measure it.Mikie wrote:How much do you cut off? My angle grinder is itching to go this afternoonOOOOMS wrote:Did mine is Dec....literally 15 mins.
Loosen the bolt on each side (one)
Unclip the seat so that it can move forward (as if mod has been done)
Tape up the hook with insulation tape or use a bit of paint.
Push the seat up into the original position
You should have a 'mark' where it should be cut off now
.....Cut
- Town: Kyalami
- Real Name: Mike
Excellent thanks.OOOOMS wrote:You will have to measure it.Mikie wrote:How much do you cut off? My angle grinder is itching to go this afternoonOOOOMS wrote:Did mine is Dec....literally 15 mins.
.....Cut
I had some pics but can't seem to find 'em now....
- stephanvaneeden
- Vehicle: 2012 Hilux 3.0 D4D D/C 4X4
- Real Name: Stephan
Hak die seat nie uit as jy met 'n helse gejuig tot stilstand kom nie.
stephanvaneeden wrote:Hak die seat nie uit as jy met 'n helse gejuig tot stilstand kom nie.
Ja.....as jy hom te kort afsny.....
- Cleaner
- Real Name: Ernst
- Club VHF Licence: X31
Dis die eerste ding wat ek op my trok gedoen het. Het dit op my pa sin ook gedoen. Vat letterlik 10 min, met 'n ystersaag, om te doen. Met 'n grinder gaan dit jou 3 min vat. Soos gesê, lig die onderste sitplek en voel hoeveel die boonste sitplek nodig het om uit te haak. Ek het seker so 10mm moes afsny en dit werk sonder enige ander modifikasie.
Op my pa se trok het ons die bracket wat agter teen die bak vas is een tik met 'n hammer gegee toe pas syne ook perfek.
So, either or, sny 'n stuk af en buig die bracket wat teen die bak sit tot dit reg pas. Deur die bracket te buig kan jy ook 'n beter fit kry sodat daar minder rattles is.
Die agtersitplek het ook nog nooit vanself oopgeval, maak nie saak hoe hard ek briek of hoe skuins die walle is waarteen ek afry nie.
- Town: Kyalami
- Real Name: Mike
Thanks guys.
This is the best no cost mod on the Vigo in My opinion, very easy to do and voila, "secure" space added for storage
The hardest part was unscrewing the seat, unclipping it, and rebolting it back, but even that my 7 year old son could do.
GreatMikie wrote:Thanks guys.
- BenRich
- Town: Boksburg
- Vehicle: Hilux 4.0 V6 4x4 BF Goodrich KM2 MT Old Man Emu Suspension, ONCA Rocksliders, Safari Snorkel, Stofpad Bashplate's National Luna Duel Battery System, Engel Fridge
- Real Name: Bennie
Gentlemen,
That rattle in the back was driving me nuts...never could figure it out. Anyway a bit of fuel pipe and presto.
That's what I love about the forum
Thank you
Thank you
Great stuff! Glad it's sortedBenRich wrote:Gentlemen,
Thank you
- Town: grassy park cape town
- Vehicle: 99 s/c hilux 4x4 2.7i long range tank & dual battery; 2003 nissan x-TRAIL (4X4)
- Real Name: charl
Ok ! great idea but I dont have a back seat
Will have to get a Vigo to test the theory soon!!!
You won't be sorry.....ROOFER wrote:Ok ! great idea but I dont have a back seat
Just make sure it's a D/C
- stephanvaneeden
Myne is gesny ! Werk lekker vir die gewere.
- Vehicle: 3.0 D4D DC, BMW 320i
- Real Name: Ian
I used instructions from the Aussie forum http://www.newhilux.net" onclick="window.open(this.href);return false; to do my mod so here are some pics;
Remove the back seat, I used masking tape to mark the cutting lines to leave 43mm after the cut; Ready to cut; After the cut showing exposed metal; Apply a bit of duco and rest proofing; The left over bits measured 24mm; It works like a dream. One has to lift the seat to 45 degrees to disengage the back. When the back is engaged it is vas and won't come down even with a high pull force. I have had no rattles at all. I have mounted my DC to DC charger behind the seat and can keep bits and pieces as well including my 2 burner gas stove.
Hope this helps - Ian
- Cleaner
- Real Name: Ernst
Very nice post with pictures and all!
I did not even remove the seats when I did mine. all and all a 10 - 15 min job.
- Vehicle: Hilux 4X4 3.0 D4D
- Real Name: Pierre
Simplest mod ever. I have also been looking for the source of the rear seat rattle for a long time. Just killed 2 birds with one mod and it only took 15 minutes.
- AM Racing
- Real Name: Dylan
Did you know: By drilling out the rivets holding the hooks, inserting a 20mm spacer and then bolting them up with 8mm bolts you will have enough space for a tapered 100lt water tank. I will be getting one in next week for this mod so will take some pics and post 'em
- TOYODA
- Vehicle: '89 YN67R with Ford V6 3.0
- Real Name: Tiaan
Now that is a great idea.AM Racing wrote:Did you know: By drilling out the rivets holding the hooks, inserting a 20mm spacer and then bolting them up with 8mm bolts you will have enough space for a tapered 100lt water tank. I will be getting one in next week for this mod so will take some pics and post 'em
I'll be keeping an eye open for this one.
- Andre de Kock
- Town: Alldays
- Vehicle: Toyota Hilux D4D double cab 2.5 srx 4x4
- Real Name: Andre
Just cut my back seat hooks shorter. Works like a charm!!! Cant believe they are not actually designed like this!
- hendrik.earle
- Town: Potchefstroom
- Vehicle: Toyota Hilux 4.0 V6 d/c a/t, 60mm lift, steeltop canopy, Custom Bullbar, Custom roofrack, WHEELS:vacancy open for 35x12.5r15
- Real Name: Hendrik
Did mine without cutting anything. Just bend the bracket on the cab downwards. Best part is you can 'fine tune' the bending until it is exactly right. no cutting and 100% reversible if you don't like it.
We never really grow up, we only learn how to act in public.
- AM Racing
- Real Name: Dylan
As requested; the water tank behind the seat
Correction to my previous post, this is a 40lt tank. You need to drill out the rivets on the hooks and insert 20mm spacers to move the backrest forward. You could go bigger but you will need to space the seat further forward on the lower bracket.- Kaaskrul
- Town: Port Elizabeth
- Real Name: Pierre
How do I unhook seat?
Force it upwards or how??
- AM Racing
- Real Name: Dylan
You unclip the lower catch, lift the base so the backrest lifts as well and then tilt it forward.
- Kaaskrul
- Real Name: Pierre
Cool!AM Racing wrote:You unclip the lower catch, lift the base so the backrest lifts as well and then tilt it forward.
Think I only lifted the bottom part up once since I had the Hilux
- Town: Kyalami
- Real Name: Mike
Surely thats going to push the back rest more upright, and anyone sitting there ends up sitting in a very upright uncomfortable position?hendrik.earle wrote:Did mine without cutting anything. Just bend the bracket on the cab downwards. Best part is you can 'fine tune' the bending until it is exactly right. no cutting and 100% reversible if you don't like it.
- hendrik.earle
Not al all, the bracket moves down, not forwardMikie wrote:Surely thats going to push the back rest more upright, and anyone sitting there ends up sitting in a very upright uncomfortable position?hendrik.earle wrote:Did mine without cutting anything. Just bend the bracket on the cab downwards. Best part is you can 'fine tune' the bending until it is exactly right. no cutting and 100% reversible if you don't like it.
- Town: Kyalami
- Real Name: Mike
And you have no rattles?
- hendrik.earle
Not at the moment, if I get rattles I can just bend it back up a bit.
- Town: Kyalami
- Real Name: Mike
mooihendrik.earle wrote:Not at the moment, if I get rattles I can just bend it back up a bit.
- AM Racing
- Real Name: Dylan
Uncomfortable?! My seat works just fine
- Kaaskrul
- Real Name: Pierre
Tried this. No go.AM Racing wrote:You unclip the lower catch, lift the base so the backrest lifts as well and then tilt it forward.
Cant get the back to unhook.
Even put my finger behind the seat and can feel it lift up from the hook, but before you get to the point for it to unhook, it starts going down again the more you lift the bench seat(I know this is normal).
At at 45 degree angle, it still needs to lift another 10mm, but it doesnt, it goes down again. So, no unhook
Can I be this dof or not??
- Kaaskrul
- Real Name: Pierre
What I also want to know, if it is this easy as lifting seat up and unhook, why do the mod in the first place? What is to gain then?
I think I'm missing something important here about this mod, or I'm the Ice Cream kind of the week
- hendrik.earle
The seat does not unhook if standard. So there is wasted space behind the seat.
Thats why we do the mod to get the seat to unhook and fold down.
- AM Racing
- Real Name: Dylan
The base needs to be unbolted then you cut the hooks shorter, or as mentioned bend the eyes down. Hence the need for the mod
- Kaaskrul
- Real Name: Pierre
AM Racing wrote:The base needs to be unbolted then you cut the hooks shorter, or as mentioned bend the eyes down. Hence the need for the mod
Why did you not say so when I asked in the first place
Or did you think my bakkie came out the factory with the mod done already
No probs hehehehee, will unbolt it the weekend
- AM Racing
- Real Name: Dylan
Thought you read the post from the top But wait thats not all,
If you pump the spare wheel to 6 bar your headlight fluid will fill up on its own! Hey?! (and who said there was a bunch of useless information on the forum )
- Royco
- Real Name: Roy
Don't like an angle grinder near my bakkie - or seats!!hendrik.earle wrote:Did mine without cutting anything. Just bend the bracket on the cab downwards. Best part is you can 'fine tune' the bending until it is exactly right. no cutting and 100% reversible if you don't like it.
This is fantastic advice!! Works like a charm!!
Thanks Hendrik!
- Aquanaut
- Town: Durban
- Vehicle: Hilux 3.0D4D
- Real Name: Basil
where can I get a tapered water tank for behind the backseat?
- Vehicle: Fortuner
- Real Name: Shaun
Reviving an old post here. With the water tank installed is the backrest not to far forward for comfort?AM Racing wrote:As requested; the water tank behind the seatCorrection to my previous post, this is a 40lt tank. You need to drill out the rivets on the hooks and insert 20mm spacers to move the backrest forward. You could go bigger but you will need to space the seat further forward on the lower bracket.
I suppose I should rather be asking your passengers
Thanks ZS1RA
- AM Racing
- Real Name: Dylan
No.it was no more uncomfortable than normal....
- Town: Centurion
- Real Name: Piet
Ek sê baie dankie vir die persoon wat hierdie mod uitgedink het. Werk baie lekker vir die gewere...
