Petrus
Myne het ook amper soos daai eine gelyk.
except for the base you use the off set reducer with the cap at the back and then build in the cadac lighter
I can tell you that if filled with deo correctly and the right size spud, You can take down a fully grown man at 50 meters.
The trick is to NOT use to much deo/lighter fluid. You need more air for the stronger combustion otherwise it just waistes the fuel.
And Thys all I can say is, IT WASN'T ME
![Blushing :blushing:](./images/smilies/blush2.gif)
used that alot growing up, never really worked though
![Laugh2 :laugh2:](./images/smilies/laugh2.gif)
